588,141 active members*
5,943 visitors online*
    Mar 2007
    67
    SX3 disassembly trouble
    I'm trying to disassemble my new SX3 to remove the grease. I've removed the bolts from the bearing support plate on the left and right ends of the table, and removed the plate from the left end. I can't separate the table from the motor on the right, however. If I pull hard enough on the table, I move the table with the motor (the ball screw turns along with the motor). Any suggestions? Thanks.
    Jan 2007
    122
    Ya mine was a little tricky as well
    What I ended up doing was taking a set of feeler gages and using them as leverage. On mine I was not able to pull it directly off but I was able to wiggle it up and down slightly by gently pulling on the motor. So what I did was open a gap inserting the feeler gages into the gap. From here I used the feeler gages as leverage to slight draw the plate off of the pins. I repeated the process with a thicker stacked of gages until it slipped off of the pins.
    Apr 2007
    30
    Quote Originally Posted by Involute View Post
    Don't forget that you have taper pins locating the parts relative to each other, as well as the M6 caps screws which hold the parts together. I have found that a sharp tap was enough to move the bearing / stepper / coupling / mounting-plate assembley, with the taper pins, away from the table or cross slide assembly respectively.
    Note, My experience may be somewhat different to yours. I am retrofitting a Syil kit to my X-3.
    Regards,
    Russell
    Perth, WA.
  1. Trouble
    By extreme in forum DIY CNC Router Table Machines
    Last Post: 07-11-2010, 10:14 PM
  2. 8" Rotary Table Disassembly
    By ChrisJ in forum MetalWork Discussion
    Last Post: 01-25-2008, 08:08 AM
  3. More PIC trouble
    By robe_uk in forum CNC Machine Related Electronics
    Last Post: 10-10-2006, 09:13 PM
  4. Bridgeport knee clutch disassembly
    By eatanimals in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2004, 12:50 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
