588,487 active members*
6,089 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > SX3 Spindle Motor Wont Turn ON
Results 1 to 6 of 6
    Jun 2005
    31
    I need help with a problem with my SX3. When I turn the power on to the mill the green power indicator light comes on, the spindle speed LCD display blue back light comes on, but there is no indication on the display. I mean nothing on the display.
    Also, if I try to start the spindle motor by hitting the start button, nothing happens. It is as if the machine is dead.
    The model number on the motor controller is: FC1000WJYA(6.2) with a manufacture date of 2006.07.25.
    Things I have checked are:
    1) 20 amp fuse on AC power line is good.
    2) 20 amp fuse on motor controller is good.
    3) checked for loose connections and everything is tight.
    4) looked for burn spots or burned up components on the PCB and none were found.
    5) 8 wire connector at the bottom of the board has the following voltage readings relaive to ground.
    S1 K3 K4 +5V GND SA SB SC
    83Vdc 80Vdc 80Vdc 6Vdc 0Vdc 0Vdc 6Vdc 0Vdc
    Kind of odd to see 6 Vdc on a connection labeled +5V but I traced it down to an LM7806 (6 volt regulator) and the PCB is stenciled 7806 next to the part. Go figure.
    6) The connector on the right hand side of the PCB where the 120 Vac comes in has the following readings relative to ground.
    L1 N1 FG U V W
    125Vac 0Vac 0Vac 14.8Vac 14.8 Vac 14.8Vac
    7) Checked the wiring harness for continuity from motor controller to push button PCB located on the front of the machine. Wiring harness checked out with no shorts.
    8) Checked the tapping button electrical switch for shorts or grounds. None found.
    I would appreciate any help in getting the mill back up and running.
    Oct 2006
    44
    Not sure if it applies to the SX3 but when faced with a similar situation with my X3 being 'dead' I have usually forgotten two things
    1) The speed pot wasn't at zero before starting
    2) The spindle guard wasn't closed
    Alternatively as it's an SX3 you could just have a knackered controller - pretty common unfortunately. Without detailed schematics it's an almost impossible job to diagnose.
    Jun 2005
    31
    M100,
    I have a call into Grizzly for tech support. The person on the phone admitted that he was not an expert on the SX3 and that he would have one of their electrical experts give me a call within 24 hours.
    I'm still waiting for the call.
    May 2007
    715
    Did you check the emergency stop button?
    I had a similar problem with mine after I bought it. It ran for a few days and the controller board went out. They replaced it and it has been fine ever since.
    Jun 2005
    31
    Yep, checked the emergency switch and it isn't the culprit. I can even hear the relay energize / de-energize when I push the emergency switch or the chip gaurd switch.
    Nov 2004
    320
    on the sx3 there is a problem in the z axis dro that shorts the motor if i mind right
    been mentioned on here before
    do search
  1. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
  2. new machine, motor wont run?
    By 300sniper in forum Tormach Personal CNC Mill
    Last Post: 10-12-2007, 02:52 AM
  3. Boss 5 series 1 BP, spindle wont start
    By signweld in forum Bridgeport / Hardinge Mills
    Last Post: 11-17-2006, 01:21 AM
  4. Ver 7.0 Eztrak 2 axis. Spindle wont turn
    By MrMudd in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:18 PM
  5. Motors wont turn
    By moto21 in forum Mach Software (ArtSoft software)
    Last Post: 09-22-2005, 04:13 PM
