Syil Machine Step Calculation
Our stepper drivers are designed and built in-house. As far as I know, there is nothing out there like it. In the same driver, you can customize how many steps you want to a much higher degree than most drivers. Since it is unique, here are the steps you will want to input in your controller based on our stainless ball screws and computer speed:
Ball Screw Calculations
Ball Screw is Metric 5.08 TPI
Stepper per rev 200
Micro Steps
2 4 5 10 20 25 50 100
2032 4064 5080 10160 20320 25400 50800 101600 Steps per Inch
Maximum Traverse Speed at 25000 Hz
738 369 295 148 74 59 30 15 Inches Per Minute
Maximum Traverse Speed at 35000 Hz
1033 517 413 207 103 83 41 21 Inches Per Minute
Maximum Traverse Speed at 45000 Hz
1329 664 531 266 133 106 53 27 Inches Per Minute
Direction, Commitment, Follow Through
