I was fortunate enough to work with Syil Canada this weekend to upgrade my mill to x4 electronics. Prior to the upgrade the standard electronics and the drive motor would bring the spindle up to full speed in 45 seconds.
The upgrade took about 3 hours in total...mostly because we were chatting and taking it pretty easy.
The first move was to remove the SX3 faceplate, and in my circumstance, to remove the manual drill press handles, the clock spring, etc. I had to install a bolt as well to facilitate the removal of the quill pinch bolt, as there no longer is a hole in the new cover for the previous bolt system.
We next removed the Seig main power board and connected the new mainboard. In order to mount the board to the existing standoffs, we had to relocate the main power cable to just below the main switch, as it was hitting the heat sink and not allowing the board to align with the standoffs.
This new board also allowed us to remove the board at the bottom of the enclosure...which will free up some space for the future (in my case for a second 5 axis board to be used as a breakout board and a 2nd parallel port (to be used for my touch probe and a future optical sensor).
Once this was all installed and a bit of testing done, we were able to get this thing up to 3500 rpm in about 5 seconds.
I still have to build permanent mounts for the faceplate, and some covers for the new holes in both sides of the spindle housing, and then repaint the machine in the new yellow color.
Keith has also ordered a 6800 rpm motor for me to install. To make this work I have to source out some ceramic bearings, and work on cooling fans, but once this is nailed down, I will be able to easily run the machine up to 6500 rpm.
