603,946 active members*
2,249 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Syntec CNC Router Machine MLC-077 (R44.12) Alarm
Results 1 to 4 of 4
    I have started my new Syntec CNC Router Machine with ATC but when I started it the first time, it gave an alarm "MLC-077 (R44.12) Tool Magazine return failure alarm" I have tried everything I know but can't resolve it. It is not even changing the tool or doing calibration.
    Mar 2024
    53
    Re: Syntec CNC Router Machine MLC-077 (R44.12) Alarm
    Quote Originally Posted by luqman62742 View Post
    Hlo friend
    I am application engineer working on Syntec controller, already working with many clients from other countries.
    contact me at [email protected] & +918168294379 ( my whatsapp). Send me alarm photo on my whatsapp
    Regards
    Pankaj (+918168294379 whatsapp )
    Apr 2004
    5951
    Have you asked Syntec tech support about this? That would be the first thing to try: https://www.syntecamerica.com/
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    Sir, You working on Syntec controllers ??
    Nov 2011
    491
    Hi dear friend~The most likely problem is that the cylinder is a little clogged, and the knife sleeve rebounds slowly or does not return to its position, causing the system to time out and alarm. If the problem is not serious, you can adjust the buffer screws at the two ends of the cylinder to solve it. If it is more serious, you can only open the cylinder for cleaning.
    You can contact us, maybe we can solve it for you?
    Email: [email protected]
    Whatsapp/mobile: +86-15064026772
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Thank you! The problem is now solved. The problem was due to the ATC sensor, it was not working. Reconnecting the wires solved this problem. I appreciate your help.
  1. Replies: 7
    Last Post: 01-25-2024, 04:42 AM
  2. MLC 70 (R44.5)1# Inverter alarm. Syntec
    By Cory88x in forum Chinese Machines
    Last Post: 01-14-2024, 03:37 AM
  3. MLC 78 (R44.13) PLC ALARM
    By JasonWhyte in forum Chinese Machines
    Last Post: 01-30-2023, 12:12 PM
  4. Syntec 6mb tool change alarm mlc 76
    By Bascil in forum Chinese Machines
    Last Post: 05-11-2018, 01:38 AM
  5. Need Help, syntec MLC alarm 76 R44.11 PLC alarm
    Last Post: 01-03-2018, 12:48 AM
