587,978 active members*
3,831 visitors online*
Results 1 to 4 of 4
    Jan 2009
    39
    Question System Variable Z Work Shift
    Gentlemen,
    I have a Kia lathe with a Fanuc O-TD control on it and I need to know what the system variable for Z axis work shift (not G54 to G59 workpiece offset)
    but the work shift. Thank You
    Feb 2004
    142
    #5203
    Feb 2006
    1792
    Actually #5203 is for Z-axis external offset on a milling machine. On a lathe, it is #5202.
    For work coordinate shift, the system variable is #2601 (for Z-axis). It shifts all the coordinate systems (G54 etc) by the specified amount, in the opposite direction. For example, if Z-display is 100, it would change to 110, if you specify #2601 = 10.
    Coordinate shift is not available on milling machines.
    Feb 2004
    142
    oh yea... duh... sorry... memory ain't the greatest anymore
    :withstupi
  1. work shift
    By teamus in forum Hardinge Lathes
    Last Post: 06-10-2009, 11:32 AM
  2. Replies: 2
    Last Post: 03-20-2009, 09:54 PM
  3. Shift option on Fanuc 6M system, very OLD controller
    By shape in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-13-2009, 08:59 PM
  4. c axis work shift
    By Atlas_Too in forum Fanuc
    Last Post: 10-13-2008, 06:14 PM
  5. Automatic work shift on lathe, is it possible?
    By DonutSlayer in forum G-Code Programing
    Last Post: 05-28-2007, 05:48 PM
