603,344 active members*
4,034 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > system Wiring diagram, BMI Trak W/LCD needed
Results 1 to 6 of 6
    Jan 2006
    Does anyone have a copy of the Bridgeport:
    System Wiring diagram, BMI Track Series W/LCD
    Drawing #59-1127
    I'm trying to find the remote start switch terminals for the EZTRACK controller.
    I found a blurry copy in the main control cabinet of the mill, but I can't read the terminal numbers or the connector numbers.
    Also, is it possible to drip feed this controller through the serial port?
    Thanks.
    Nov 2004
    3028
    I have to get to the office and see if I have that schematic. I should.
    The original software was designed that the 2 axis did not have DNC capability. The 3 axis did. At version 5, the same disk was used to load both 2 and 3 axis so I believe that both styles should DNC. You would have to read the manual though because my memory is of these doing DNC from the floppy or DOM (disk on a module). I believe the serial port was for program transfer and not for DNC.
    George
    Jan 2006
    4
    I have a copy its in .tif format so I can not attach it here.
    if you send me your email and i can forward it
    Nov 2004
    3028
    My apology. I do not have it. I hope the gentleman above came through for you.
    I have put the word out to my service engineers that I need a copy.
    George
    Jan 2006
    4
    on its way.
    dave
    Jan 2006
    Got the Schematic - THANKS!!!!
    Thanks for your help - it is just what I needed.
    And thanks to CNC Zone for providing this forum.
    -Dan
