588,410 active members*
5,239 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jun 2011
    692
    Re: Table Material
    You might want to use threaded inserts (such as helicoil,) anywhere you plan on using threads frequently. The larger bearing surface of the threads, plus using some adhesive should help keeping the threads from getting worn out.
    There are other sorts of threaded inserts specifically for plastic that are friction fit.
  2. #22
    Aug 2010
    43
    Re: Table Material
    I might try that as time goes on, but I don't think there will be a need. An M6x1 gives me 12 threads. That's a lot. If does degrade, I can just bore out the threaded holes, make some round stock of the stuff on the lathe, and solvent bond it in!
Page 2 of 2 12
  1. How do you place material on table safely
    By TRed in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-29-2016, 02:10 AM
  2. hot table to glue material to table
    By tommy78 in forum Uncategorised WoodWorking Machines
    Last Post: 09-05-2014, 07:26 AM
  3. table material idea
    By ashb82 in forum DIY CNC Router Table Machines
    Last Post: 10-15-2013, 08:02 PM
  4. honeycomb table material?
    By bgirit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-26-2008, 03:25 AM
  5. setting up material larger than table
    By Runner4404spd in forum MetalWork Discussion
    Last Post: 03-06-2006, 09:12 AM
