588,121 active members*
4,906 visitors online*
    Nov 2013
    12
    Table size - Pros and Cons
    I am a Newbie CNC hobbyist, with a nice woodworking shop. I also am an accomplished machinist, with a full metal welding fab/machine shop. Never done anything CNC. I am planning a CNC Router table, and would like any input as to the size I should build. I will NOT be doing any commercial work, and my projects are generally modest in size. I will be using (in some combination) linear slides and bearings, ball screw actuators, Nema24 steppers and driver modules, driven by Mach3. I initially thought that a 4' x 4' was a no brainer, but now it seems like overkill. I would like to know is 2' x 4', or even 3'x4' would be a better choice. My woodshop suffers from the proverbial "10 pounds of crap in a three pound sock" affliction, so a bench top unit would be preferable. A 2'x4' would fit nicely on one of my existing benches. Thanks for any input on size pros and cons.
    Ozzie
    Mar 2003
    35538
    I'd say go with 3x4.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2009
    137
    Just know there is a big difference between table size and cutting size. For a full 24"x48" cutting surface, you will probably need at least a 36" x 60" table. Maybe a little larger to give the Z axis room to move. Add at least 12" to your cutting size for the finish table size. For a 3 x 4 size figure at least a 4 x 5 table.
    Dave
  1. Pros and Cons
    By SB2C-1 in forum Surfcam
    Last Post: 12-13-2010, 11:48 PM
  2. Pros and Cons of X4, CNC Jr...
    By timberwolf5480 in forum Benchtop Machines
    Last Post: 04-16-2009, 04:46 AM
  3. pros and cons
    By stirling in forum Stepper Motors / Drives
    Last Post: 08-28-2007, 03:40 PM
  4. Pros and Cons of Two Designs
    By PaulH in forum DIY CNC Router Table Machines
    Last Post: 10-22-2005, 03:22 PM
  5. What are the pros and cons of
    By cncadmin in forum CNC Machining Centers
    Last Post: 05-19-2003, 06:31 AM
