587,700 active members*
4,527 visitors online*
Thread: Tabs - Again
Results 1 to 20 of 31
Hybrid View
    Mar 2010
    Tabs - Again
    Again I am back to looking at tabs for SC. One of the reasons I started trying BobCad. I am trying to mill several small parts, but really do not want to take the time to create fixtures or soft jaws. really not needed as they are simple 2D designs.
    I never got any of the suggestions before to work on creating tabs in SC. Anyone had any luck simulating them?
    I did read a post (lost it) where someone created 2D circles and then had SC ignore them, but I never could figure out how to do that.
    Any suggestions would help.
    I do have the option of adding tabs in Alibre as a alternate configuration, but sometimes I am not sure how I will machine it when I am designing the parts.
    Jul 2004
    595
    Quote Originally Posted by Magnum164 View Post
    If you do a search on the SC forum I posted on it there quite a while ago. Its quite easy. Just draw a small rectangle or circle at the edge of the part and use extrude and make it a restricting zone(where you want the tabs). Ive used it many many times and it works great.
    David
    Mar 2010
    David,
    Actually you mentioned some words i missed on the other post. I see how this can work now.
    Only problem is I do not see a restriction zone in 2D contouring?
    Jul 2004
    595
    99.9% sure there is. I do 2D contouring all the time and create tabs that way. Im not at my CAM computer now to post a pic, but look again, I know its there.(or Im goin nuts )
    Mar 2010
    Quote Originally Posted by David Bord View Post
    I know it should be there.. Will check after dinner But it does show it in the help documentation.. I just don't see it. It may just be the way I set my OP up, will try on a fresh file later as well.
    Mar 2009
    50
    You can also extrude them as fixtures. There is another way of doing this. Instead of 2D contouring use "Jet Cutting" . You can add bridges in this operation, however you will have to add a Z depth and a correct spindle speed using a editor (notepad++). I have done this several times and it works well. I have an active request for SprutCAM to add the bridges to 2D contouring.
  1. Holding tabs?
    By LessPaul in forum Dolphin CAD/CAM
    Last Post: 03-29-2010, 11:50 PM
  2. Holding Tabs
    By webgeek in forum EdgeCam
    Last Post: 01-26-2010, 08:22 PM
  3. Tabs not selectable
    By Turbo1zz in forum Mastercam
    Last Post: 12-01-2009, 07:06 AM
  4. Tabs How and Where?
    By Mr.Chips in forum Uncategorised CAM Discussion
    Last Post: 03-04-2008, 03:08 PM
  5. Tabs in V9
    By MikeA in forum Mastercam
    Last Post: 03-21-2004, 12:55 AM
