Howdy,
Bare with me, total noob, still learing correct terminology!
Would some kind soul post its data plate for the cnc versions upgraded spindle motor or enough info to find a spec sheet on the net. Or just its rpm, shaft diameter, how its mounted, anything i might need to know to replace it?
I have a cnc 2019cr on its way to australia and hoping to find a motor to work on our 240v 50hz power =)
While im at it, is 1/4 hp generally enough? would 1/2 or more be overkill? how much slower/faster rpm might i be able to go
Already considered a setup transformer but the frequency differance will be detrimental to speed/heat
Thx!
