603,832 active members*
4,324 visitors online*
    Aug 2004
    3
    Taig CNC ready setup help??
    Hello guys. I am new to the cnc milling scene and have been doing lots of reading the last couple of weeks and need some help to setup a Taig cnc ready mill.
    Can someone please recommend a good setup for a Taig. I will mostly be dealing with Aluminum metals. I need a setup that can work with metals for long periods of times!!!
    ----Setup i am thinking about----
    MILL...Taig CNC ready mill 2019CR
    SOFTWARE....I would like to run a XP Windows based software if posible(guessing Mach 2).
    DRIVER BOARD... XYLOTEX Three Axis Stepper Motor Drive
    STEPPER MOTOR....???? Need help here. I am guessing something with 200-300oz
    SPINDLE MOTOR.....???? Need help here. Is the one that comes with the Taig good or can it be upgraded to something with a more powerfull motor for working with metals?
    POWER SUPPLY....??? Need help here.
    All comments are welcome
    Thanks in advance guys for your help
    A.j
    Mar 2003
    6855
    Aug 2004
    3
    Would a 200-3000z work better or is that to much for a XYLOTEX driver?
  1. Anyone bought a Taig CNC from A.Rotondi Engineering?
    By juaumu in forum Taig Mills / Lathes
    Last Post: 06-28-2006, 06:40 AM
  2. Machinist - CNC Setup & Operator in FLA
    By sundara in forum Employment Opportunity
    Last Post: 12-24-2004, 04:35 PM
  3. Taig lathe Threading and CNC questions
    By anoel in forum Mini Lathe
    Last Post: 01-12-2004, 10:43 PM
  4. My Taig Setup And Ready To Go!
    By WOODKNACK in forum Taig Mills / Lathes
    Last Post: 01-04-2004, 01:47 PM
  5. Master5 Taig Mill Setup
    By Jcadwell in forum Mach Mill
    Last Post: 11-09-2003, 12:53 AM
