587,460 active members*
3,407 visitors online*
Results 1 to 11 of 11
    Aug 2006
    673
    Taig way lubrication
    Ok, so i'm sick of using ATF. I'm having nothing but problems latley with longer CNC programs. Here is my problem, after the program runs for maybe 1/2 hour or so, the ATF seems to wear off and then the x and y axis start binding. I'm running at 10ipm and it seems to jog fine around 30ipm, so I'm fairly sure my gibs aren't to tight.
    So, what do you guys recomend for lube, for longer CNC programs (with and without coolant running).
    Oct 2004
    168
    Medium Way Oil is what you want to use.
    Quote Originally Posted by CS900 View Post
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
    Aug 2006
    673
    thanks for the reply nick. do you know of any good places to purchase this?
    Mar 2007
    196
    I always use Mobil One.
    Aug 2006
    673
    Quote Originally Posted by bilinghm View Post
    as in the engine oil? what weight?
    Nick, what Iso grade is medium equivalent too? I see Mcmaster sells 68 and 220. I'm going to guess the 220 is a bit thick for my little taig.
    Mar 2007
    196
    Yes, the 10W30 motor oil. I have used it for years.
    Aug 2006
    673
    I'll have to try that, I know i have some extra moble1 kicking around in the garage somewhere.
    Oct 2004
    168
    I bought medium way oil from the local oil dealer. But I think MSC, etc carries it. A gallon lasts a long time.
    As for the weight of way oil, I have no idea.
    Way oil has additives that allow it to cling to the ways better, so it's not running off the z-axis as quickly...
    Nick Carter
    www.cartertools.com
    Aug 2006
    673
    ok. I guess I'll call up some local machine shops and see if they have any good local places to look. Thanks again Nick.
    Dec 2007
    15
    Try and see if you can get some Mobil "Vactra no. 2" - made for the job !
    http://www.mobil.com/Canada-English/...a_Numbered.asp
    Dave
    Aug 2006
    673
    Yeah, Mcmaster has it. They also have the Vectra 4, which is the heavier weight stuff. I guess I'll try the motor oil first, then I'll see about ordering actual way oil.
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. X2 maintainance/lubrication
    By Pretorien in forum Benchtop Machines
    Last Post: 11-08-2007, 01:17 PM
  3. Lubrication
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 04-29-2007, 07:13 AM
  4. Ballnut lubrication
    By Haydn in forum Linear and Rotary Motion
    Last Post: 12-08-2006, 03:36 AM
  5. Lubrication
    By BeerFizz in forum Benchtop Machines
    Last Post: 11-10-2005, 01:25 AM
