Hello, first post here, I'm a newbie.
I have a Closed Loop Servo MicroMill DSLS 3000. I've been having success with rotation axis milling using DeskProto but recently ran into a snag.
I was running a 1/32" cutter and after 5 minutes of running the machine I got an emergency estop trigger. I was not cutting aggressively since it was the finishing pass and my speed was only 5 ipm. I was no where near the physical limits of the machine. I pushed go to z and I got another estop. Then I jogged the Z axis up away from the model and went to jog the x axis and estop triggered again.
Thiis where I am stuck. I cannot jog at all with the x axis but can with the other three axis. I did let the wax chips build up quite a bit, could they have jammed something up within the screw mech? I am able to turn the screw by hand so this leads me to believe the x axis is not physically stuck. I have absolutely no idea where to go from here.
So to recap everything jogs except for the x axis.
Any idea what this could be? Any advice would be greatly appreciated!
Vince
