Hello everyone,
I just bought a Taig CNC mill, and I am running it with EMC2. Unfortunately, I have run into a problem.
I was facing a block of aluminum with a 3/8" two-flute carbide end mill, and all of a sudden it started sinking into the block. I shut it off. I tried a couple more times and the same thing happened each time. The computer showed no change in Z position, and the drill bit was not slipping in the collet.
The only explanation I can think of is that the bit was pulling the whole Z-axis down into the aluminum. It is only a 280oz-in stepper motor holding it up after all (if I remember that number correctly). I thought this seemed unlikely because the depth of the passes was only about .01", which seemed extremely shallow. So my question: does this seem normal?
Some more questions: If I am right about what's going on, are there some basic guidelines I can find somewhere about depth of cuts vs. holding torque (and probably some other variables such as RPM & cutter diameter)?
Could I fix this problem just by increasing the RPM and keeping everything else the same?
Would the problem be solved if I used a smaller diameter end mill?
In general, what do all of you seasoned CNC experts have to say about this situation?
Thanks!!!
Nic
