603,848 active members*
2,693 visitors online*
Results 1 to 7 of 7
    Oct 2010
    134
    Tailstock move....
    Hi again,
    I'm working on a LB4000ex with a P200LA, I want to move the
    tailstock (axe W) but not with the M code, is it possible to do it with
    G0 or G01, I want to use it without pressure, I will put something on the
    center, and use it as a part catcher, I don't want my part to fall on the
    way cover as I part-off my rings. Or any ideas?
    Did try G0 W0, but nothing move and no alarm, looks like the machine is waiting for something....
    Sorry for my english!
    Mar 2009
    1992
    rapid feederate override?
    what kind of tailstok You have? Maybe You nedd to select subspindle first?
    is it NC- tailstock?
    May 2012
    100
    If it is a hydraulic tailstock, only M code will work i guess,
    unless it is an axis with encoder.
    Oct 2010
    134
    It's an NC tailstock, and no it's not the Rapid Feedrate,
    Yes it is an axe (W) with position on the screen.
    Once settle, I call it with M55(pressure against part) and retract with M56, but I want to move it with the W axe. (G0 W5.0)
    Mar 2009
    1992
    I'm surprised, that no one answered Your question still.
    Obviously, some condition is not satisfied. maybe chuck clamp, maybe turret in safe position. tailstock quill must be retracted, that's for sure. The way to find out is:
    wait for error message; if it takes longer than 20 minutes, it doesn't works at this case
    or
    check "diagnostics" screen
    or, the worst:
    read manual carefully ...
    May 2004
    4519
    The tailstock position is programmable. The quill position is not. There should be limit switches under the cover for quill position that can be adjusted so that fully extended is a legal condition. Then you can adjust for tailstock position to obtain near zero part pressure.
    Oct 2010
    134
    OK, the service man came in for training for an other machine and I asked him.
    So the way (did a sub prog.) to do it is :
    OTIN
    VCHSW=1 (tailstock on)
    M847 (tailstock back to it's limit)
    M55 (retract position) as programmed on the nc tailstock screen
    M166 (tailstock interlock off or something like that)
    G04X2.0 (pause)
    VCHSW=0 (tailstock off)
    RTS
    So now I can use the tailstock as a part catcher.
    Hope it can help someone
  1. plunge after first move and retract after last move
    By Joesph Jackman in forum Mastercam
    Last Post: 02-24-2012, 06:15 AM
  2. Gadget ideas to move the TL-3 tailstock.
    By TXFred in forum Haas Lathes
    Last Post: 08-06-2011, 01:59 AM
  3. Replies: 6
    Last Post: 03-14-2011, 09:41 PM
  4. Getting CNC lathe tailstock to move
    By lkenney in forum MetalWork Discussion
    Last Post: 02-12-2009, 11:02 PM
  5. The X-Axles... to move or not to move!
    By Wild4aces in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 08:26 PM
