603,939 active members*
2,352 visitors online*
    Sep 2006
    19
    Takisawa CNC Lathe Communication Problem
    Hello..
    i am use Takisawa CNC Lathe
    Model : TW-20
    Date : 1996
    Takisawa Fanuc
    i am first time cnc lathe trying to connect to PC..Rs232, but it's not working
    085 Cmmunication Alarm,
    i am Useing Haas cnc milling machine connect to PC..Rs232, working is good..
    i am trying to Haas cnc milling Rs232 Cable,and software, to Takisawa cnc lathe but it's not working good, 085 Alarm
    kindly help me...
    Masood
    Dec 2003
    24260
    List the contents of parameters
    0002
    0012
    0050
    0552
    0553
    What baud rate etc are set on the PC, is it set for software handshake?
    Al.
    Albert E.
    Feb 2011
    14
    kindly check cable configuration and setting parameter on pc according to fanuc.
    thanks
