588,146 active members*
6,205 visitors online*
    Mar 2007
    76
    Question Tamagawa Fa-coder
    I'm working on a Mighty Comet with Mitsubishi MDS-A servos and Type HA80NT-E30 servomotors. The encoders are Fa-coder TS5170N11. I was getting a S03 servo alarm #50. It appeared a drive had went South. It was in position #2 (Y). I swapped with #3 (Z), Then Z alarmed out. I repaired the drive. I left it in Z. It wouldn't move, so I swapped it back with Y, nothing, and then swapped again. Now I have Y and Z down. I was wondering if the encoder (on Z) could be the problem and caused the known good drive to go bad. Does anyone have a pinout so I can test it? Any other suggestions? I have since repaired both drives but have not installed them yet due to the possible encoder problem.
    Thanks in advance. (Machine Down)
    Hotrob
    Feb 2008
    13
    SAME PROBLEM HERE
    DID YOU FIX THIS, I HAVE THE SAME KIND OF PROBLEM?
    Mar 2007
    76
    Yes.
    Yes, I fixed this. First and foremost had a failed servodrive. I repaired it in house. Bottom line, the shaft was broken on the Y-axis servo motor. It was a little hard to find out that was the problem. All is well. Did you get yours fixed?
    Hotrob1
    www.aa-repair.com
  1. Fanuc pulse coder pinout?
    By Jonne in forum Servo Motors / Drives
    Last Post: 02-02-2013, 03:49 AM
  2. Tamagawa Seiki AC servos
    By yoopertool in forum Servo Motors / Drives
    Last Post: 08-18-2007, 05:12 PM
  3. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum DNC Problems and Solutions
    Last Post: 04-23-2007, 03:55 PM
  4. Fanuc Pulse Coder
    By Derek.C in forum Fanuc
    Last Post: 01-04-2007, 03:24 AM
