588,385 active members*
5,258 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Tangent lines joining two arcs
Results 1 to 19 of 19
    Jul 2008
    28
    bought a mastercam 10 book a while ago, still cant figure out how to join two arcs by tangent lines. asked a few guys at work(familiar with 8 or 9) we can click the first line endpoint. the autocursor kicks in and joins the second arc tangent. i cannot figure out how to start the line at the tangent point on the first arc. any help is very appreciated.:rainfro:
    click on Help....works every time.
    Mar 2006
    1013
    Well if your using 10 (X) and no one has turned off the auto cursor, It should be easy. The problem is that people tend to turn that off because "It didn't work that way in V7. So I dont like it".
    If Autocursor is on.... When you move near an object, it will show you the options for attaching the new geometry.
    So, If you have an arc on the screen, and you select the Line command, and then move your cursor around the arc slowly, you'll see the icon next to the pointer change to different options.
    Mike S. is right Look in the help for AutoCursor.
    BTW: Books are one way to go... But Video training make the process a little more obvious. Consider looking at the link below.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Jul 2008
    28
    help file doesnt help(ive looked through the help section, also the manual that comes with the program). they are very basic. only one other guy in my company using 10, and he's in our other plant. the autocursor wont click on the first point. im to the point of figuring it out mathematically then inputting the angle in. but there has to be a better way. mc8, is easy, a co-worker showed me how to do it, in that version in seconds.
    Aug 2007
    95
    tangent line
    create-line-tangent-2 arcs-select the 2 arcs works simple and easy for me,but i am running version 9.1.
    Mar 2006
    1013
    So your using X ? Is the Autocursor On?
    I cant see why this is so hard for you.
    In X: If you pick Create Line and pick the first arc and then pick the second, you cant not make it tangent. Make sure your not picking an end point or center point. You you specifically pick an end point, you get the end point. If you just pick the arc (any where that's not an endpoint, Midpoint or center, and then grab another arc, it will work.
    If that doesn't work: Check the icon on the Ribbon bar that shows a line with a Tangent arc. Is that selected? It's on by default. You would have had to turn it off for it not to work.
    Might I suggest this....
    http://www.tipsforcadcam.com/product/TFM-CDStartX
    Mike Mattera
    Mar 2006
    1013
    Watch this video..
    http://www.tipsformfg.com/bin/X_Line_Tangent.wmv
    Mike Mattera
    Apr 2003
    3578
    I would like to add a short video to .I give a brif thought on auto curser and this option.
    http://www.mastercam-cadcam.com/crea...20tangent.html
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Jul 2008
    28
    Exclamation
    for some reason the arcs dont highlight like they do in the vids. and i cannot drag the line around the arc. maybe something wrong with some settings in my mastercam. even though i watched the tangent disabled in autocursor, and still draw a tangent line. something must be wrong with the mastercam im using
    How is your Auto-Cursor set? Do you know what the AC is? How do you turn it on and off? How is this thing set? (see pic) It should be set to Single.
    Apr 2003
    3578
    the auto curser does not effect the create line tangent mike and it should not be set to single. his Auto high light might not be set.Also what version of MastercamX are you using Mike is showing the first mastercamX release are you running a later version?
    Cadcam
    Quote Originally Posted by cadcam View Post
    Then what is his problem Jayson?
    Apr 2003
    3578
    yongchiprsnapr,Please review my picture for some settings.
    Mike I am sorry you did not like my reply. but by chance did you review my video as I showed how it works and that the Auto curser does not effect it.
    I know I did it in X3 but it has not changed in the last few years.
    Oooppss that was suppose to be "Quick Note" on my picture.
    Cadcam
    Apr 2003
    3578
    Just tried it in MCX MR1 this is the MR release after MCX release. Works the same.
    Cadcam
    I never said I did not like your reply. I have no problem with that feature in any version.
    Jul 2008
    28
    well, i finally took my computer over to the other plant. went down their configuration settings copying them exactly. now it works as easily as it should. dont really know which one was the problem. im just happy its working now. i was afraid the computer was too slow to run 10 or something. didnt want to learn 9.thanks Mike S., cadcam, Mike M., and anyone else who posted in the thread offering help. if already got another question lol. later
  17. #17
    Apr 2003
    3578
    I am glad to hear all is good. and that all of us were help some were.
    Cadcam
  18. #18
    I am so glad you were able to fix the problem.
  19. #19
    Feb 2005
    11
    Question Tangent to two curves not arcs
    Tangents to two arcs are no problem for me. However, I cannot figure out how to draw a tangent to a circle and to a spline or a tangent to two ellipses, etc. Any one have a tip for drawing a tangent to two curves that are not arcs?
  1. points to lines/arcs
    By vmax549 in forum Autodesk
    Last Post: 10-14-2008, 02:05 PM
  2. line tangent from...
    By Castle1 in forum Rhino 3D
    Last Post: 09-21-2007, 02:08 AM
  3. lines-arcs vs spline problem
    By metlcutr55 in forum Uncategorised CAM Discussion
    Last Post: 07-07-2006, 04:16 PM
  4. tangent point
    By bob in windsor in forum MetalWork Discussion
    Last Post: 12-23-2005, 10:05 PM
  5. Lines and Joining them
    By scottsss in forum Rhino 3D
    Last Post: 07-29-2003, 11:41 AM
