588,201 active members*
4,882 visitors online*
    Apr 2010
    Tangential Fabric Cutter Problems
    Hi
    I am using Mach 3 with SheetCAM as the post-processor. I have built a fabric cutter with a tangential A-axis. Would also like to have 2 pneumatic cylinders, 1 for the knife and 1 for a pen.
    I have the following 3 problems:
    1) When the machine is running in a straight line along the x and y axiz, The blade (a-axis) rotates in a circles as it moves in a straight line. However, when I run one of the tutorial programs of Mach3, then this problem does not occur.
    2) There is a pneumatic cylinder that controls the Z-axis of the machine. The problem is that when the blade is supposed to be in the air, it is pressed onto the material and vise versa. I have tried changing the active high and low on the Z-axis direction pin. When I do this the direction changes while jogging, but not when a program is run. (In other posts they talk about setting the Z to +200 and -200 which controls the Z height. Where does one set this?)
    3)I would like to be able to run a pen and a knife. I understand that I would need a different offset for each cylinder,but how would I control which cylinder is activated and moves up and down along the Z-axis
    Thanks so much
    Help will greatly be appreciated
    Regards
    Mar 2003
    35538
    Sounds like all of these may be able to be worked out in SheetCAM. I'd ask Les.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2010
    Hi ger21
    I have already been in contact with Les and he has been a great help so far.
    Just thought maybe someone else could shed some light.
    Thanks alot
  1. Cutter comp problems
    By scottsss in forum G-Code Programing
    Last Post: 02-14-2015, 07:38 AM
  2. Cutter compensation problems
    By Richster in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2008, 10:27 AM
  3. Key seat cutter problems?
    By Von Mikey in forum MetalWork Discussion
    Last Post: 06-19-2008, 04:03 AM
  4. to control tangential cutter w/oscillating
    By avengine in forum Machines running Mach Software
    Last Post: 04-20-2006, 04:23 PM
  5. Building Fabric Cutter with blade
    By handrade in forum Community Club House
    Last Post: 08-29-2005, 11:30 PM
