587,406 active members*
3,374 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > tap cycle HAAS m2
Results 1 to 12 of 12
    Apr 2009
    95
    tap cycle HAAS m2
    After working with bobcad on a crash problem and a total reinstall of my system. I can now create an NC file. The Problem I have is with the TAP cycle. When I run the NC file on my mill the tap cycle starts moves the spindle to .100 of part. the spindle CW rotation stops for an instant and restarts and there is no more movement. Not sure what is wrong.
    Jim
    Dec 2011
    361
    Try this post. It is certified by Haas to work on their machines and we have many customers that use this post successfully.
    Attached Files Attached Files
    Mar 2012
    1570
    You also may not have a ridgid tapping onption on your machine and may need to use a floating tap instead.
    Can you post the code in this thread of what you tried to run that didn t work?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2009
    95
    Ridged taping is turned on. purchased 6 months ago.
    The machinre is a TM2P.
    Tried the canned tap cycle in the mill it works fine.
    Dec 2011
    361
    Take a look at the post I provided for you. See if the canned cycle output looks correct for your machine. Just let me know.
    Dec 2011
    361
    This is how the code outputs with a center drill, drill, and tap with the OEM post that I provided below.
    G00 G20 G90 G17 G40 G80 G49
    T1 M06 (0.125 )
    G90 S2383 M03
    G00 G54 X0. Y0.
    G43 H1 Z0.1 D1 T2
    M08
    G81 G98 Z-0.125 R0.1 F1.6685
    G80
    M05
    M09
    G00 G91 G28 Z0
    M01
    T2 M06 (0.201 )
    G90 S1482 M03
    G00 G54 X0. Y0.
    G43 H2 Z0.1 D2 T3
    M08
    G81 G98 Z-0.6104 R0.1 F2.0752
    G80
    M05
    M09
    G00 G91 G28 Z0
    M01
    T3 M06 (0.25 )
    G90 S733 M03
    G00 G54 X0. Y0.
    G43 H3 Z0.1 D3 T1
    M08
    G84 G98 Z-0.7 R0.1 F36.65
    G80
    M05
    M09
    G00 G91 G28 Z0
    G28 Y0
    T1 M06
    M30
    Apr 2009
    95
    It looks like I can tap again .... Thanks.
    Jim
    Jun 2012
    514
    jbcj....were in the USA are you located?
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    Jan 2006
    73
    well the G81 G98 Z-0.6104 R0.1 F2.0752 is the Drill not going to help your Tap.
    G84 G98 Z-0.7 R0.1 F36.65 your tap is going deeper then the Drill,this is not a good thing.
    Dec 2011
    361
    That is purposeful as that code is not mean to run, just show how the canned cycle works.
    Apr 2009
    95
    Quote Originally Posted by Big Chips View Post
    Oregon (Orygun) Portland area
    Apr 2009
    95
  1. Haas Probing cycle
    By Traceman in forum Haas Mills
    Last Post: 09-06-2021, 03:55 AM
  2. G76 Thread cycle Haas SL-30
    By haaszard ahead in forum G-Code Programing
    Last Post: 12-14-2012, 03:26 AM
  3. Haas G73 canned cycle
    By rcs9250 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-13-2012, 02:07 AM
  4. canned cycle on Haas
    By GITRDUN in forum G-Code Programing
    Last Post: 11-22-2006, 06:44 PM
  5. Haas G85 Boring Cycle (canned)
    By DEAN in forum Haas Mills
    Last Post: 12-08-2003, 05:12 PM
