588,055 active members*
4,174 visitors online*
Results 1 to 4 of 4
    tap M05 ? G84?
    Please,
    What is the best solution on cnc lathe for drilled M05 ?
    Or there is some better trick?
    Thanks!!
    Aug 2009
    1573
    Re: tap M05 ? G84?
    M3 for righthand tools maybe...before drilling Z
    Who is control of the machine...aka Fanuc 0T or some china man?
    Model number of yours helps ...whendialing 911
    Re: tap M05 ? G84?
    That is okay.
    I switch M03 and drill and after switch M04 in opposite direction so the path can be created.
    Is there any other trick please?
    Re: tap M05 ? G84?
    You are right It is Fanuc OT and the manual is GFZ-61397E/02.
    Please I am new in this...
