587,593 active members*
3,789 visitors online*
Thread: taper thread
Results 1 to 5 of 5
Hybrid View
    May 2006
    8
    taper thread
    I have a vertical machining center running a mitsubishi meldas 520 am control
    and I am trying to cut an internal 1"-11.5 NPT using a single point threading tool and am having no luck whatsoever trying to figure out what the book is telling me to do as far as a program to accomplish this. any help would be greatly appreciated! Thanks
    Jul 2003
    1220
    gcrandall
    I can't help with Mitsubishi Controller but can supply a file containing a full list of XYZ coords.
    You would need to cut and paste the section to suit the radius of your tool.
    If you are interested advise approx dia of cutter and wether you intend to cut from top or bottom.
    May 2006
    8
    thanks for the offer, but I figured it out.
    Dec 2005
    3319
    This is a give and take message board, your learning experience may help someone else out.
    Would you mind sharing the method you used to figure it out???
    May 2006
    8
    here is a copy of the program the cuts the threads. it does it in 3 passes:
    T14M6
    G55
    G0X0Y0
    G43H14Z3.
    S4500M3
    Z.5M8
    G1Y.3808Z.3652F30.
    G91
    G2.1X0Y-.0515I0J-.3808Z-1.5652P18F30.
    G90
    G1Y0
    G0Z3.
    Z.5
    G1Y.4008Z.3652
    G91
    G2.1X0Y-.0515I0J-.4008Z-1.5652P18F30.
    G90
    G1Y0
    G0Z3.
    Z.5
    G1Y.4168Z.3652
    G91
    G2.1X0Y-.0515I0J-.4168Z-1.5652P18F30.
    G90
    G1Y0M9
    G0Z3.
    M19
    G28Y0Z0
    M30
