588,572 active members*
10,008 visitors online*
Thread: tapping
    Dec 2004
    3
    tapping
    Having problems with tapping a hole. Using a 1-14 3 flute bottoming tap. trying to tap a casting about an 1 1/4. Problem is the machine is thrown into alarm almost to the bottom of the hole. When I get the tap out, it is packed with shavings. I thought maybe a spiral flute might help so I ordered one today. Should be here tommorow. If this don't work, does anybody got anymore suggestions? Maybe tap halfway, pull out and then finish tapping?
    Thanks,
    Shawn
    Shawn
    Mar 2003
    4826
    Shawn,
    What material is it? If it's cast iron, then a straight flute tap would be okay, maybe a plug version instead of bottoming, though.
    What kind of machine? Does it do repeat rigid tapping?
    I would think that it would be good to take a couple of passes to do the hole, so that you could get some new lube on the tap as it progresses farther down.
    Have you considered thread milling? This is what I would recommend for the cleanest looking threads, and far less brute force is required to drive a thread mill than a tap.
    If its a blind hole, a spiral flute is generally the correct choice for normal tapping.
    First you get good, then you get fast. Then grouchiness sets in.
  1. Tapping head any good?
    By kong in forum MetalWork Discussion
    Last Post: 04-19-2005, 09:49 PM
  2. tapping 303 stainless
    By bobcor in forum MetalWork Discussion
    Last Post: 03-28-2005, 11:58 PM
  3. tapping chrome plated shaft?
    By sixpence in forum MetalWork Discussion
    Last Post: 01-30-2005, 12:23 AM
  4. Rigid tapping on a BPT TC1G w DX32 control
    By machintek in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2005, 02:06 AM
  5. Tapping
    By MPE racing in forum Uncategorised CAM Discussion
    Last Post: 11-06-2004, 07:42 PM
