587,240 active members*
3,380 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > tapping M1.6 holes with the Tormach tension/compression head
Results 1 to 8 of 8
    Dec 2012
    161
    I'm considering buying the TTS ER16 tension compression tapping head for the purpose of tapping some small (m1.6) holes. Does anyone have experience machine tapping holes so tiny? Would the tension compression head even work on this, or would the spring just strip the threads?
    Jun 2007
    168
    you should thread mill thoses holes.
    Jan 2007
    1332
    I have had very good results with tapping small holes such as 2-56 blind holes shown here using a TTS mounted Procunier 1E reversing tapping head with my Tormach.
    Don
    Tapping 2-56 on Tormach video by miltons_stuff | Photobucket
    Jun 2006
    3063
    Quote Originally Posted by FuriousGeorge View Post
    Material and tap type will make a difference. I've down hundreds of #4-40 through holes in aluminum with spiral point taps and had nary a problem.
    I'm about to do some #3-48 blind holes in aluminum and will be trying a form tap.
    Whatever you do, don't just use a standard tap, especially one from the HW store.
    Mike
    Mar 2009
    1863
    I would definitly use a form tap. By doing it with a form tap, you should be just fine as long as you don't hit the bottom of the hole.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jan 2007
    1332
    For tapping small blind holes in 6061-T6 Aluminum I use a Balax form tap. The form tap doesn’t cut thread but rather forges the threads and therefore no chips— especially good for blind holes. I have tapped 10s of thousands of 4-40 blind holes in 6061-T6 using the Procuier 1E reversing tapping head, forming tap, and Relton A9 tapping fluid on my Tormach with excellent results. One of the reasons IMO that the Procunier tap head works so well with small taps is the double-cone "cushioned" clutch of the Procunier. Also the Procunier tap head stops within 1/3 rev and there is no need for dwell time. I also know that the 4-40 tapped formed holes work well because I am the one who installs the screw in each hole that I have tapped. I have my own quality control and can tell how well the 4-40 hole was tapped. In my experience the Procunier and Balax form tap make a very strong consistent threaded blind hole as proven by the 10s of thousands of holes that were made with a SS screw installed.
    Don
    Jun 2006
    3063
    Quote Originally Posted by Steve Seebold View Post
    Thanks - there is plenty of room for a deep hole so bottoming out the tap won't be a problem.
    Jun 2006
    3063
    Quote Originally Posted by Don Clement View Post
    Don
    I use a Procunier 1E on my manual mill and like it there, but the Tormach tension-compression head is more convenient for me on the Tormach and has worked well so far for through holes with gun taps. Hopefully, it won't have any problem with the Morse form taps that Mari Tool sells.
    Mike
  1. Anyone selling thier Tormach Tension Compression Tapping Kit?
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 10-12-2011, 06:22 PM
  2. Tension/Compression Tapping Head??
    By Gundawg in forum Tormach Personal CNC Mill
    Last Post: 10-11-2011, 11:29 PM
  3. Procunier tension compression tapping head
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 09-07-2011, 02:58 AM
  4. Tension/Compression vs. Reversing tapping head
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 07-29-2011, 12:30 PM
  5. Reversing Tapping head vs Tension/Compression tapping Head
    Last Post: 01-25-2011, 03:39 PM
