603,982 active members*
2,664 visitors online*
Thread: TB6560
Results 1 to 20 of 20
Hybrid View
Elektryk TB6560 03-31-2012, 01:27 AM
agguilar the info is from the person... 03-31-2012, 01:52 AM
Elektryk so all i use is 3 pins? GND,... 03-31-2012, 02:32 AM
HorridHenry All 4 pins share a common... 03-31-2012, 03:08 AM
Elektryk so if i connect the GND to... 03-31-2012, 03:26 AM
Elektryk umm ive tested it but it no... 03-31-2012, 04:32 AM
Elektryk Anyone?:confused: 03-31-2012, 11:51 PM
HorridHenry For heavens sake....its 4... 04-01-2012, 05:02 PM
Elektryk yes ok.... ok so wire the... 04-01-2012, 05:16 PM
Elektryk got me even more confused by... 04-01-2012, 05:45 PM
Elektryk got it :) changed the potr... 04-01-2012, 05:57 PM
HorridHenry Look at the pic and double... 04-01-2012, 06:03 PM
Elektryk yes i got it..... pin 13 is... 04-01-2012, 06:16 PM
HorridHenry Old scrap video,CD/DVD... 04-01-2012, 06:34 PM
Elektryk male plug :P :D thank you ;)... 04-01-2012, 10:38 PM
MoneyPit*10 If you have problems sourcing... 04-02-2012, 02:11 AM
Elektryk hehe oki :P :D :) thank... 04-02-2012, 04:20 AM
    Jul 2009
    99
    Question TB6560
    ive got this driver board ...
    http://www.goodluckbuy.com/images/de...s/_DSC6103.jpg
    and this is the manual look at it please... i think theres something wrong ?
    http://www.fozztexx.com/CNC/HY-TB3DV-M_3Axis_Driver.pdf
    and im having troubles figuring out the 4 pin interface ( limit, stop)
    since there is 5 pins and i got 5 limit sw and a stop btn,.... i really have no idea hot to connect it..... for me it doesn't make sense
    and the manual says and shows 4 channel inputs interface....
    input 1 - corresponding P10
    input 2 - corresponding P11
    input 3 - corresponding P12
    input 4 - corresponding P13
    now the definition of 1-PIN15 of Manual interface:
    P10 - Z Limit
    P11 - Y Dir
    P12 - Y Step
    P13 - STOP
    missing something...?
    all it says :
    4 channel inputs interface- Can be used for XYZ limit and emergency stop !....
    HOW???
    please help me... im almost done with the machine
    Jun 2008
    36
    the info is from the person that sold me the board....
    ONBOARD RELAY CONTROL FOR TB6560 BOARDS
    The Toshiba board relay is addressed through pin #9 on the connection cable for the 3 axis
    board, and pin 2 for the 4 axis board.
    3 axis board setup
    In Mach3, output signals are configured through the main configuration menu, under the "Ports
    and Pins" utility. Open the Ports and Pins utility, and you will see a page with multiple tabs; click
    on the "Output Signals" tab. Enable "Output #1" (green check mark) and make sure the port
    number is correct (usually "1"). Under the column labeled "Pin Number" type in "9", and
    also make sure the corresponding "Active Low" column contains a red "X". That's it for Mach3
    configuration.
    Now, within a G-code program, the Toshiba relay can be controlled using two M-function
    commands, "M3" to switch the relay on and "M5" to switch it off. It's very important for safety
    reasons that any program using M3 to turn this relay on ALSO has an M5 command (before the
    end of the Gcode program) to turn it off - otherwise whatever is being controlled (via relay) may
    remain ON after the program ends.
    Substitute pin 2 for pin 9 for the 4 axis board.
    WARNING
    The relay on board may be rated higher than it actually can handle. Because motors draw near
    three times their rated amps on startup, this on board relay can be destroyed or damaged with
    repeated high amp starts,
    an you can use this file http://www.cnczone.com/forums/1036152-post2.html
    Jul 2009
    99
    so all i use is 3 pins? GND, P10, P11 ?
    and what about z- Limit?
    Feb 2012
    HOW???
    All 4 pins share a common ground.
    Jul 2009
    99
    Quote Originally Posted by HorridHenry View Post
    so if i connect the GND to either P10,12,13.. will triger limit.... and GND to P11 will triger Estop???
    Jul 2009
    99
    umm ive tested it but it no work ... the Estop doesnt work.....
    welll... all i get is limit trigge....... however i connect two pins i get limit trigger ..... any ideas?
    Jul 2009
    99
    Anyone?
    Jul 2009
    99
    Feb 2012
    For heavens sake....its 4 fire doors that will lead you through the same door out of the building,wire the switches as MoneyPit illustrated....mind you there is 6 limit switches really.
    lol
    Jul 2009
    99
    lol
    yes ok....
    ok so wire the limit sw like here on pic... but again what with the estop...it keeps on messing my mind up
    Jul 2009
    99
    got me even more confused by saying its a 6 limit relay...
    its easy for you guys to say since im new to thins
    Jul 2009
    99
    got it
    changed the potr and pins in mach3..... and GND + PIN13 + EStop
    Feb 2012
    Look at the pic and double whats switches are on the limit switch lines and just one E-stop switch,although there's no rule that says you can't have two.
    so it would look like this.....
    Jul 2009
    99
    yes i got it..... pin 13 is the estop.... ive checked and it works....
    all those 3 pins show limit triggered and only pin 13 show external estop requested.....
    now any idea wher i can get that female plug? ive been looking all over the place and no luck
    Feb 2012
    Old scrap video,CD/DVD rom,radio, loads of electronic scrap things might have one...even with the wires still attached.
    Oh and its a male plug.
    Jul 2009
    99
    male plug :P thank you :wee:
  17. #17
    Mar 2012
    If you have problems sourcing the connector in question, it is availlable as Ebay Item 330632508179 from this seller http://stores.ebay.ca/HUBBARD-CNC-INC
    If you want to wire up your own get some JST 2mm (millimeter) 5 pin connectors off Ebay (170797376727).
    Or get these (170815030696). Pre-wired JST 2mm, male and female with 300mm of cable all ready to go.
    Keep five, send me the rest.
    MP*10
  18. #18
    Jul 2009
    99
    hehe oki :P
    thank you again
  1. TB6560
    By Elektryk in forum Stepper Motors / Drives
    Last Post: 07-03-2012, 05:58 PM
  2. tb6560-v2 red
    By tranber28 in forum Controller Cards
    Last Post: 07-03-2012, 05:31 PM
  3. TB6560 are they all the same?
    By Gamble in forum DIY CNC Router Table Machines
    Last Post: 08-24-2011, 07:01 PM
  4. TB6560 Help
    By fordgt72 in forum Stepper Motors / Drives
    Last Post: 03-17-2011, 06:56 AM
  5. tb6560 help me!!!!!!!!
    By AvioP in forum Stepper Motors / Drives
    Last Post: 08-02-2010, 09:06 PM
