588,152 active members*
4,734 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560 3-axis driver manual control
Results 1 to 5 of 5
    Nov 2009
    17
    I have this driver
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=260509188593
    And it has connector for manual control.
    Can someone please explain me what PINs do I need to connect to move steppers, and on what PIN's can I connect LEDs so I can see them lightning when stepper moves.
    This is the pinout of connector:
    P1- X STEP
    P2- X EMPOWE
    P3- SPIND
    P4- X DIR
    P5- Y EMPOWE
    P6- Z DIR
    P7- Z STEP
    P8- Z EMPOWE
    P9- Y LIMIT
    P10- Z LIMIT
    P11- Y DIR
    P12- Y STEP
    P13- STOP
    P14- GND
    P15- 5V/VDD
    Also, I can change "Buffer Settings" with jumpers on board.
    Can someone please explain me what this means?
    I can chose this settings :Fast, 25% , 50% , Slow
    Thanks!
    Aug 2009
    65
    Quote Originally Posted by kish89 View Post
    I have this driver
    P1- X STEP
    P2- X EMPOWE
    P3- SPIND
    P4- X DIR
    P5- Y EMPOWE
    P6- Z DIR
    P7- Z STEP
    P8- Z EMPOWE
    P9- Y LIMIT
    P10- Z LIMIT
    P11- Y DIR
    P12- Y STEP
    P13- STOP
    P14- GND
    P15- 5V/VDD
    Output:
    very likely non at all.
    The manual connector seems to be just inputs.
    So I fear no way to connect moving indicator lights except solder some wires to the LEDs on the board.
    Control: you need to:
    a) enable the driver channel you what to move (x EMPOWE[R])
    b) select the wanted direction (x DIR)
    c) clock in pulses for stepping (x STEP)
    SPIND is the spindle relay ... and so on.
    Not exactly rocket science when you translate the pin names.
    But actually for manual control you better use the control program on the PC.
    Every movement via manual control is invisible for the controller program.
    It apeares like lost steps to it.
    It become critical if you could select some manual input during execution of a milling program by the PC. That throws the program completely off track and trashes your workpiece. You better have then a master switch that disables the manual control safely while on automatic control.
    Manual control ist just usefull for moving the machine when the PC (or the controller program) is off.
    I don't need no stinking manual mode on my maschine
    This has to do with the chopper current regulation of the chip and sets the decay mode of the current in the coils. Just thake a look into the chip documentation for details.
    Actually I have no idea what is best as it might have to do with the inductivity of your motors, the micro stepping mode and the supply.
    To fast may cause noisy operation and possible step losses, to slow and your motor may overshoot on deceleration and have step losses too.
    This gets more critical at high speed of course.
    The key may be to adjust it so that the coil currents can follow most accurately the commanded steps at your fastest speed.
    But thats difficult without detailed calculation using all the variables of the specific machine.
    Peter
    Nov 2009
    17
    Quote Originally Posted by dilbert0815 View Post
    Output:
    I'm just testing the board features, when I'm using controller program, surely I will not use manual control
    Just wanted to know how it works.
    Peter
    When I set settings to low, I'm having high pitching sound from steppers, but they are working fine.
    But, when I set settings to high,25% or 50% , steppers are silent and doesn't have that horrible sound, but they are hot like a hell.
    So, probably best way would be to leave it low.
    Aug 2009
    65
    When this is without movement then the current is set to high and should be reduced until you think it's ok.
    Without movement the coil current should be constant.
    The slow mode means the current looks like a saw tooth.
    I would rather recommend increasing it to 50% and reducing the current setting.
    What stepping mode are you using?
    Stay away from full step as might generates up to twice the disipation in the motor depending on the stop position.
    2 out of the 4 phase positions cause 100% current in both coils in full step mode.
    Half step mode reduces the peak to 71% worst case in both coils.
    When one coil is at 100% the other always is at 0%.
    So the worst case is 200% current for full step vs 142% for half step.
    As power is proportional with current squared this means twice the dissipation for full step in worst case without movement.
    Nov 2009
    17
    I will try reducing current and increasing buffer.
    I'm using 1/16 microstepping.
    I will let you know results.
    thanks for help
  1. eBay TB6560 Stepper Motor Driver Boards
    By Mad Professor in forum Stepper Motors / Drives
    Last Post: 07-03-2012, 04:38 PM
  2. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2012, 02:21 AM
  3. TB6560 3-axis driver from ebay
    By kish89 in forum Stepper Motors / Drives
    Last Post: 07-01-2011, 01:10 AM
  4. Manual Control of z axis with progam running
    By kevoler in forum Mach Plasma / Laser
    Last Post: 11-11-2008, 12:57 AM
  5. Software for single axis manual control?
    By Corruptor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-08-2008, 04:39 AM
