Re: tb6560 x axis with problem
Originally Posted by
CitizenOfDreams
Considering the fact that you can buy up to eight TB6560 boards for the price of one Gecko, they remain a perfectly valid option for budget-limited hobbyists.
You can buy about 3 6560's for the price of 1 of my THB6064AH kits (which will get you most of the capability of a Gecko) and you can /repair/ one of my kits (replace the chip) for LESS than the cost of a 6560. And... it will /actually/ do 200 watts (4 amps at 50 volts) continuous where the 6560's are lucky if they can get halfway to their rated power.
And the 6560's aren't only unreliable from one unit to the next, they are ALSO unreliable over time. They will work great for some number of power ups, and then suddenly fry on power on. This is because the chip is specifically designed to have the power come up in sequence: Logic power first, THEN motor power. And every single cheap chinese board out there derives the logic power from the motor power, which means the power up sequence is backwards. The chip datasheet specifically says, in large type, that this is not ok.
If you are going to do this and be successful over the long run, buy quality.
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
