603,826 active members*
3,670 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560. Y and Z axis work fine but not the X axis
    Dec 2013
    47
    Hello!
    I have a TB6560 board where the Z and y axis work just fine, but the X axis wont move.
    Anyone had this problem before?
    Apr 2014
    7
    Re: TB6560. Y and Z axis work fine but not the X axis
    Mine did the same thing while in stepConfiguration. Once inside the actual program it should work. if the leds for the x axis dont light on your board, then your Pins from the parallel port are not set right in the program.
  1. 5 axis breakout board and 3 single axis drivers tb6560, not working
    By MROX15 in forum Stepper Motors / Drives
    Last Post: 11-06-2013, 07:34 PM
  2. tb6560 5 axis
    By drago2012 in forum Stepper Motors / Drives
    Last Post: 02-18-2013, 06:24 AM
  3. Jet JMD-18 (RF-31) fine feed z axis
    By dukegnarley in forum Benchtop Machines
    Last Post: 02-01-2013, 05:54 AM
  4. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  5. 3 axis setup: 2 motors work fine, 1 locks up
    By chozo in forum Stepper Motors / Drives
    Last Post: 11-04-2004, 02:57 AM
