588,344 active members*
5,390 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > TCC v3 - keeps inserting G28 - why
    Dec 2005
    165
    Hi Folks,
    Some help would be most appreciated.
    TCC v3 seems to add the following code between tool changes:
    G91 G28 Z0. M09
    G28 Y0.
    Particularly the g28. At the moment I edit this out after generating the g code file. How else do I stop this happening. Have I missed something in "settings"?
    Secondly it seems that I can't edit this code in the g code window. I can only edit the G code when a single operation is highlighted and then the offending code is not visible.
    Any pointers in the right direction would be great.
    Phil (chair)
    Jan 2006
    4396
    Question G28
    I am New to TurboCAD but not G-Code.
    This G-Code is used to return an axis to the home position for tool change.
    Ex. G91G28Z0M19
    G91 Incremental Motion
    G28 Home
    Z0 Z postition Home for ATC
    M19 Origin Spindle
    Usually after a tool is finished being used one would send it home in the Z axis and sometimes Y and Z to change tools on some machines.
    Is the TurbCad post sending a tool home before you are finished using it? Like maybe when you are doing a pocket in steps or set D.O.C.?
    This may be a simple fix in the TurboCAD Post.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
