587,682 active members*
3,716 visitors online*
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    May 2008
    84
    Re: Techno cnc Lathe
    Quote Originally Posted by johnohara View Post
    AR1911~
    Missed the "H" in the first part number. Apologies.
    KL23H2100-35-4B vs. KL23H2100-30-4B
    That will let you check the pdf file for each drive to compare specs.
    Aha! Thanks
    The link I provided is an article that has a sub paragraph titled "Performance Factors."
    It does a nice job describing the "electrical time constant" of a stepper motor. Which
    is why those values are included in the motor's spec.
    ~john
    I bookmarked that to read this week, certainly looked useful.
    After reading through the G320X setup procedure, tuning those servos looks pretty fussy.
  2. #42
    May 2008
    84
    Quote Originally Posted by Pplug View Post
    Let us know how it turns out. I have read somewhere that the 1000 tick encoders have trouble with the gecko servo drives, but that was years ago. I read that the drivers couldn't keep up with the encoders. I read that 300 or 400 tick encoders work best. Just take my advice with a little salt. I'm not 100% sure. I hope it works for you.
    My success or failure may be no reflection on the hardware. I'm about as green as they come on this stuff.
    I'll be a bit more confidant once I get one of my machines running on Mach3 or EMC. I need that positive feedback.
  3. #43
    May 2008
    84
    I started a thread over in the Gecko support sub-forum. I can't match up the Servo wires to the drive connections.
    I may not have enough information on the servos to get there. We shall see.
  4. #44
    May 2008
    84
    http://www.cnczone.com/forums/gecko-...ml#post1793842
Page 3 of 3 123
  1. Techno CNC Under New Ownership
    By TechnoCNCSystem in forum Techno CNC
    Last Post: 10-24-2013, 04:52 PM
  2. Techno CNC Help Please!!!
    By stevec in forum Commercial CNC Wood Routers
    Last Post: 11-18-2012, 02:33 PM
  3. Post Processor For Techno CNC Metal Lathe
    By Hodgson in forum EdgeCam
    Last Post: 01-17-2012, 11:07 PM
  4. techno
    By cabnet636 in forum Commercial CNC Wood Routers
    Last Post: 06-16-2011, 10:23 AM
  5. Techno vs K2
    By big_mak in forum Techno CNC
    Last Post: 09-09-2007, 10:20 PM
