603,350 active members*
4,841 visitors online*
    Aug 2022
    Techno-Isel DaVinci Ballscrews
    I recently acquired an older Techno-Isel DaVinci from a local high school. It has been converted to run Mach3. At one point the machine was taken apart and cleaned, but the ballscrew nuts (see picture) lost some of their bearings. It now runs rough and not as accurate. Is it possible to buy new ones? All of them need to be replaced.
    Jun 2005
    1792
    Re: Techno-Isel DaVinci Ballscrews
    The ball nut usually has a part number on one side. You can load missing ball bearing if you measure one with a caliper and order some of the same size on eBay. There are videos online that show you how to repair these. It takes a lot of patence but is doable
    Sep 2012
    230
    We have all of the ball nuts in stock. Pm or email us and we will get you taken care of. Home | Armor CNC
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
  1. johnohara's Techno-Isel DaVinci
    By johnohara in forum Techno CNC
    Last Post: 01-26-2021, 01:37 PM
  2. Techno-Isel Davinci upgrade help
    By Ferny in forum Controller & Computer Solutions
    Last Post: 08-05-2020, 12:25 PM
  3. grbl-Upgrade for Techno Isel Davinci/ISEL EP1090
    By Sebastian-Schuetz in forum Techno CNC
    Last Post: 09-12-2019, 07:06 AM
  4. Techno-Isel DaVinci Update/Retrofit
    By PiZLe_ in forum Techno CNC
    Last Post: 04-22-2018, 01:51 PM
