603,380 active members*
3,381 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > DNC Problems and Solutions > Techno LC Series 4896 Tool problem!! Please help
    Dec 2010
    7
    Smile Techno LC Series 4896 Tool problem!! Please help
    Hi, we have a Techno LC Series 4896 CNC. I wasn't at the shop when the problem arose but for some reason it will not eject the tool that is currently in it. The air pressure is on and working fine but the machine will not allow you to manually remove the tool while holding the green button down. They tried resetting the fuse box completely last night while I was out of the shop but it changed nothing. Any suggestions would be very greatly appreciated! Thank you
    Edit: The interface still seems to think the tool has dropped out because it asks you what tool is now in the machine, but it holds onto it like it never wants to let it go.
    Edit: Problem solved!
    Jun 2012
    techno Lc series 4896 tool problem¿ please help
    I have problems with the pulley shaft, apparently for wear but I have the parts manual to sort by number of parts is not if someone could provide a copy or tell me where I can see
  1. Techno LC 4896
    By mechcanoer in forum Techno CNC
    Last Post: 05-18-2012, 09:43 PM
  2. LC 4896 Accuracy Problem
    By ian12 in forum Techno CNC
    Last Post: 01-16-2010, 05:40 PM
  3. Techno Z Axis Motor Problem...
    By Rick Turner in forum Commercial CNC Wood Routers
    Last Post: 12-17-2007, 08:56 PM
  4. BP series II Interact 4 tool release problem
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2007, 12:43 PM
  5. Techno CNC LC Series Rotary
    By layertone in forum Commercial CNC Wood Routers
    Last Post: 11-08-2005, 06:52 AM
