587,684 active members*
3,095 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Techno post processor error
Results 1 to 7 of 7
    Jul 2007
    34
    Smile Techno post processor error
    Good day,
    when I post my toolpath, I get this error message, "warning-post rotary axis assignment ('rot_on_x') overwritten by operation", what does it mean, my toolpath is a surface highspeed waterline, I use Mastercam X2 mr2 SP1.
    Thank you
    Apr 2003
    3578
    It thinks you are trying to rotate the part like on a fourth axis and this machine def has an issue doing that. did you set another Tool plane then program?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Jul 2007
    34
    Hi cadcam, my WCS is top and my CPLANE is top also, I only a CNC 3 axis.
    I run the toolpath on my piece of wood and everything went well, I got this error 2-3 times when I was posting, really strange.
    Thank you
    The C plane is not top, it says it is not saved. look at all planes this may have something to do with it. Go into each of the toolpaths, go to planes and make sure in there they are all top.
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Jul 2007
    34
    Hi Steve, when I did the toolpaths, it was saved, the reason why it is not saved, it's because I reopen the drawing to make the screen capture.
    Look in planes in your toolpath parameters, planes is a button at the bottom of the toolpath page go into there and make sure all plane are top. from your picture the cplane is not on top. I was not talking about saving your part.
    Steve
    www.cad2cam.blogspot.com
    www.cad2cam.net
    Apr 2003
    3578
    this goes with Steve's thought and mind to really.
    Cadcam
  1. Error Help Techno LC4896
    By winnie in forum G-Code Programing
    Last Post: 10-24-2011, 07:13 PM
  2. "Runtime error 9 - subscript out of range" on Techno CNC interface
    By zhoudfoster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2009, 04:57 AM
  3. Question regarding Techno Post processing
    By kerrazy in forum CNC Machining Centers
    Last Post: 07-12-2007, 12:23 AM
  4. Processor check error G
    By PeteB in forum Bridgeport / Hardinge Mills
    Last Post: 01-26-2007, 03:40 PM
