I like to make my own techno vacuum table, can somebody explain the stock setup you buy from them.
I looked a the pictures on the web site, but they lack detail.
How are the manifold hoses attached to the bottom of the aluminum table?
Is there just a 2" or so dia hole cut into each extrusion and the hole is glued?
Are holes drilled in the top of the extrusion to line up with the mdf holes?
I would love if somebody would explain or if you have ideas to make your own. Thanks for your help!
