588,655 active members*
5,950 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Telescoping ballscrew cover?
    Jan 2005
    122
    I have a 4020 with the steel telescoping ballscrew cover on the Y axis. I am having problems with the the cover and aluminum washer getting hung up on the screw about half way back. The cover is fairly new and still in good condition. Anyone else ever experience this?
    Oct 2010
    Oil it
    Untwist it (slightly)
    Did you have the y axis all the way back when you tightened the ballscrew nut (ballscrew slightly offcenter causing the washer to snag on the bed)
    Is the flat section of the washer sitting under the table (as it should)
  1. Ballscrew Cover Replacement on TM-1
    By heavensoutlaw in forum Haas Mills
    Last Post: 10-24-2022, 09:25 PM
  2. ballscrew cover
    By mackeym in forum Linear and Rotary Motion
    Last Post: 04-21-2007, 04:44 PM
  3. R2E3 X Axis ballscrew cover
    By s1j1m10 in forum Bridgeport / Hardinge Mills
    Last Post: 08-24-2006, 12:43 AM
  4. Telescoping leadscrew cover?
    By phantomcow2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-13-2005, 05:32 PM
  5. Here's an idea for a cheap bellows style ballscrew cover
    By DR-Motion in forum DIY CNC Router Table Machines
    Last Post: 02-16-2005, 11:00 PM
