Temp rise in an electrical enclosure
Hi all,
I have been lucky enough to get a stainless steel electrical enclosure which I will be using to house all the electronics for a router build.
Measurements are 600 x 600 x 200 (2' x 2' x 8" for our US friends)
Will be housing all that is needed including three Gecko g201's running three 2.5 amp motors at around 65 volts and am wondering if the temp inside the enclosure will rise too much.
This enclosure is from a chemical plant and has been professionally built and has a really good seal on it. It also has a false base in it so the whole base can be built on the bench and then inserted into the enclosure. (as many may already know)
Really don't want the hassle of running a fan then having the problems of keeping the crap out and having fan vents block up.
Hopefully there is enough natural heat dissipation over such a large area and this may be enough.
I do realise I am asking "how long is a piece of string" so I suppose I am asking "do you have an airtight enclosure and does it heat up too much?"
Thanks all M
No, Little-Johnny, pomegranate is not a type of English stone.
