Had it been working previously without issue? And is it repeatable? It could possibly be an indication of a faulty sensor or even faulty, shorted, or dry solder joints. Have you opened it up to check there's no swarf blown in, and the joints all look good? If your comfortable with a soldering iron, you could just touch up all the joints, this will not damage it any way unless you linger far too long in any spot. Maybe hold the boards up to a good strong backlight and flex them minutely from opposite edges to see if there's a crack anywhere.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
