586,036 active members*
3,564 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Tensile specimen preparation
Results 1 to 6 of 6
    Post Tensile specimen preparation
    I want to make flat specimen for tensile testing with mini CNC machine. I don't have experienced in making sample with cnc. Please help me to find a suitable machine for my application. I found one cnc (TensileMill) that is only for making specimen and having the spindle rpm about 24000, what is the advantage and do 3000 rpm cnc can also make the fine cut tensile specimen.
    Jul 2018
    6339
    Re: Tensile specimen preparation
    Hi 107 - What is your budget and what materials do you want to cut? Peter
    Budget is within 15000-20000$. I want to cut .2 to 2mm thickness cold rolled galvanized steel sheet. I also want to have standard clamp.
    Jul 2018
    6339
    I presume your in USA so these are USD. Look up Tormach or similar they will have something in that range. Peter
    https://www.tormach.com/pcnc-440/
    Mar 2019
    Hi Friend,
    If you need cnc machining services,pls feel free to contact us,tks.
    Best regards,
    Tina
    [email protected]
    Anyother in AISA?
  1. Calculating vessel pressure from material tensile strength
    By Ceramic Man in forum Mechanical Calculations/Engineering Design
    Last Post: 07-22-2014, 09:32 PM
  2. machining tensile test specimen
    By sinha_nsit in forum CNC Tooling
    Last Post: 12-23-2009, 05:37 AM
  3. Tensile Specimens
    By IITStaff in forum Employment Opportunity
    Last Post: 09-09-2009, 10:59 PM
  4. machining tensile test specimen
    By sinha_nsit in forum MetalWork Discussion
    Last Post: 07-25-2009, 07:32 AM
  5. tensile strength
    By pp-TG in forum Mechanical Calculations/Engineering Design
    Last Post: 11-30-2006, 02:14 PM
