587,762 active members*
3,377 visitors online*
Results 1 to 5 of 5
    Dec 2005
    210
    Terminal Block
    I have 110v coming into my control cabinet. Then it hooks up to 10 diffrent devices in the control cabinet. But im having trouble wiring them all together with wires nuts. its alittle messy when you have all those wires. so id like to have some type of terminal block for it.
    that has 1 input and multiple outputs.
    I am also looking for a industerial type of cabinet to mount my computer into.
    Aug 2004
    2849
    Okay, well I would check mouser.com......look for terminal blocks.....what I would recommend is that you look for terminal blocks where you can buy their jumpers to make all the terminals common......look for fastons 1/4 inch or so that will work with those terminal blocks...makes for easy and reliable connections. Phoenix Contact, Berg are some of the brands...
    Check ebay for a NEMA cabinet...
    Dec 2005
    210
    Thanks for the reply ViperTX. I will look into those things. I am tring to get this thing wired up as correctly and neatly as I can.
    May 2005
    2502
    Radio Schlock also has terminal blocks and the jumpers to tie them together.
    Best,
    BW
    Jan 2013
    Simple Solution
    I know this is an older post but you guys may want to try an integrated terminal enclosure. The Enclosure and terminal block are made from a single mold allowing you to wire up everything quickly. Here is a link to a site that has them www.litecycle.com also found attached a picture of one for your reference.
