588,136 active members*
6,044 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Test cutting with Tormach 17mm insert end mill
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Nov 2005
    157
    Without wishing to Hi-jack, could I also recommend the Dijet Super End Chipper? I use a 16mm SECM quite a lot now, cutting steel rather than Aluminium, and it's actually a very good match for the Tormach.
    Cut this lump of EN8 (1045 steel) the other day, not pushing things at all really, using 2400rpm and 450mm/18 IPM feed at 1.5mm/0.060" DOC at full width (16mm) and it hardly moved the load meter at all.
    Just cut really, really nicely - smooth and very little noise. Only disadvantage was that I had to make a new TTS adaptor for it to suit the 16mm shank. Stickout from this is 2".
    Peter
  2. #22
    Apr 2004
    52
    Dave, thanks for checking. I am able to view it now.
Page 2 of 2 12
  1. Cutting steel on lathe with carbide insert. Not smooth.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 12-05-2008, 03:13 AM
  2. mounting flexible couplings to 17mm shaft
    By cowanrg in forum MetalWork Discussion
    Last Post: 04-11-2005, 06:40 AM
