603,400 active members*
2,554 visitors online*
    Sep 2003
    1490
    TEXT SIZE NOT CONSISTANT
    VECTRIC VCARVEPRO V12.7
    I'm using ARIAL and set text height to 6.0" and BOLD. Everything is typed at these settings.
    After typing all the text I convert it to VECTORS to be able to reposition the text .
    I'm making some signs and I find that I'm getting up to 0.2578" difference in height of the letters "S " and "L " on 6" high text as well as others letters having a variation in height.I
    What am I doing wrong to get such a variation in the text height?
    Or do I need to set the height of each letter one by one manually after converting to vectors? Or is there a way to change the heights easier?
    Oct 2015
    5
    Re: TEXT SIZE NOT CONSISTANT
    Round letters are always going to be larger than straight, if they weren't they would look smaller than the straight letters it's a visual thing
    Dec 2008
    3211
    I agree with olsonsigns...
    Curvature at top and bottom of letters needs to be larger than the font size to appear proportionally the same.
    Same goes with letter spacing, certain letters require different gaps to appear correct (& not get lost within the word ie letter I)
    Suggest you work in fonts to manipulate (position, size, effects etc) before converting to lines & arcs for final processing
  1. Alphacam - import text not consistant
    By LIL_MAC in forum Alphacam
    Last Post: 01-27-2022, 06:50 PM
  2. Fusion 360 text size issue
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 07-21-2016, 06:39 PM
  3. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  4. Text Editor Window Size
    By cncsnw in forum Centroid CNC Control Products
    Last Post: 05-30-2008, 07:59 PM
