We will have several kits (with English documentation) in the states shortly. Just a little late to the game.
Our ballscrews are of a high grade of Italian stainless steel. Made in Italy. Double nut.
I think some valuable points are being made here:
True, you can not expect a 400lb mill to compete with 15,000lb monsters. However, you can make a darn good effort trying, and get great results.
Conversions have a place. They can be a wonderful experience. Knowing your machines intimate details, inside and out. However, don’t be mislead in thinking it will save you a tremendous about of money over a “converted” machine. I would make a guess and say that it takes dozens of hours to begin with. When the math is complete, you will find yourself in a quandary. A great experience though for those of us who just love the tear things apart.
Direct drive or belt. Each has it’s positive and negative. My personal preference is direct drive. Simply for the fact of adjustments. When the belt is worked hard, I have noticed they do tend to lengthen and slack slightly. You can make them extremely tight, but I wonder about the loading to the stepper. Direct drive has it’s problems too. Main disadvantage is that torque is limited to the motors output. With a belt drive you can take away some speed and gain some torque, simply by gearing it differently. This gives you the choice of several smaller stepper combinations. Belt also allows for various placement choices of your stepper, where the direct drive limits you to just a few. It's like comparing a Braeburn apple to a Gala. Still apples. Some like one, some like the other.
Direction, Commitment, Follow Through
