As anyone who has read my previous rants on fiat currency and inflation knows, I warned that the U.S. banking system is literally insolvent, and I attempted to show that this is the inevitable result of the use of paper as currency.
The recent attempts by the U.S. Federal Reserve Bank (a privately owned institution) to shore up the crumbling financial sector are not only historic, but they run the risk of pushing the dollar into total collapse. The housing bubble was caused by using their unconstitutional power to fix interest rates for their own profit, expanding the money supply at an unprecedented rate. Almost all money borrowed from banks is created on the spot. Artificially low rates encourage borrowing. The resulting expansion of the money supply causes prices to increase on whatever is being purchased with that borrowed money. The expansion went on for so long that people took it as gospel that housing prices would continue to increase beyond the rate of inflation. If you could qualify for a loan to buy a house, within a few years you would have a bunch of paper equity. This equity could be cashed out if you sold the house, but most people didn't do that (because prices were going through the roof). What they did with that equity was to borrow against it, since the equity qualified them for a bigger loan. People competing for housing with this borrowed money kept demand artificially high and drove prices up. This is called malinvestment.
Now that the whole ball of string is unwinding, the Fed is stuck between a rock and a hard place, and so is the U.S. government. The entire financial sector is literally insolvent. The difference between them and you is that if you were insolvent, they would seize your assets and auction them off. But since they are the lenders (creators of money from thin air), and at the basis of the currency system (above actual producers), they cannot be allowed to fail. So they are being bailed out. The largest of them might even be bailed out by the government. Not that it matters too much who creates the money out of thin air, because the government is insolvent too. The only tool they have left in the toolbox is to print more money, and that is what caused the problem in the first place. The rock is: bail them out or they fail. The hard place is: keep printing money and the currency will collapse.
The collapse of a currency doesn't happen overnight (but it might!). It just slowly becomes more and more worthless. One reason the housing bubble hit such highs is that countries that export to the U.S. were saving their dollars, and investing them in U.S. bonds and other instruments. This has the effect of swallowing up the inflation. Temporarily. When the globe stops buying, the value tumbles faster than usual.
The lower value of a currency is the same as higher prices for everything; the currency just buys less than it used to. People are trained to think that this is inflation. Actually, inflation literally means inflation of total amount of currency in existence. The inflation happens a long time before the market reacts by granting less purchasing power to the money. So now, when the officials have to admit that inflation is a concern, and they might have to do something about it, they are lying. The inflation happened ten years ago and every year since. The purchasing power of the currency you must earn is only now beginning to reflect that, and there is a whole lot more to be accounted for before it is all over. The horse is out of the barn and ten miles away before the admission is made. Meanwhile, they attempt to hide it by pretending it just doesn't exist. The official inflation rate ignores the cost of fuel and uses a lot of other shenanigans that would be illegal to use on a tax return.
The problem they've gotten themselves (and us) into now is bad, really bad. That's because not just the banks are insolvent, but the government-backed lending houses (Fannie Mae and Freddie Mac) bundled up these loans and sold them all around the world. As in any government intervention that involves price-fixing, the laudatory goals of setting minimums for something end up causing the fake minimum to be the maximum as well. And so the lion's share of the mortgage money was backed by these unconstitutional entities. And now, they are going to be nationalized. The only solution to communist intervention in the market is eventually a total communist take-over of that market. Or allow it to fail.
But they can't allow it to fail. They must rescue them, because the bad paper is spread around the world, held by other governments and their own fiat currency banks. If that paper became worthless overnight (it is, technically), those economies would falter (and they are, already). And so they will be rescued, by the issuance of huge amounts of fake paper money. Which will come back to haunt us all in the form of higher prices. How much higher? You guess.
Every time there is a huge release of unearned currency into the economy, a class of people benefits by it. And the rest of the people are swindled by it. They create it and spend it, but you have to earn it. Once the effects settle out as less purchasing power (higher prices), the next time around, it takes more money for the thieves to get the same effect. Each round requires larger and larger infusions of cash to get the same response out of the dying patient. So the money halves in value in shorter and shorter time periods.
So, what they are up to now is throwing the taxing authority of the U.S. government behind all this bad paper in an attempt to prop up the value in the market. This might help you now, if you see what is happening and dump the paper before it falls any further. This can only work for the short term, however. The U.S. government is insolvent too, borrowing at the rate of $2 Billion per day to fund ongoing operations. It is clearly already far, far in excess of its ability to tax any more. The debt can never be paid back. The government has abandoned any schemes to become solvent through taxation, they have been forced to resort to inflation - issuing more currency- for everything they do. Including the attempt to price-fix bad paper in the market to hold the whole house of cards up.
What precipitated this rant is the following article in today's news:
http://business.timesonline.co.uk/to...cle4563171.ece
Bottom line: Gold, silver, or other commodity-based currencies prevent the issuer of that currency from stealing from the people through the silent tax of inflation. That's why all currencies in the world are now fiat, paper currencies. The temptation is just too great. The power to issue currency gives the holder of that power unlimited reign over a nation. The only risk comes from going too far, ruining the economy and starving the people, who then tend to react with violent overthrow.
The chickens are coming home to roost. It is immoral to steal. Institutionalizing immorality and implementing it on a historically large scale does not make it legitimate. It only multiplies the damage done to innocent victims. The outcome is inevitable, however long it takes for those chickens to find their way home. Here they come! When things start unraveling, innocent people are going to get hurt (more than they have already). No nation is immune, their paper money schemes are all interlocked, and private trade goes everywhere. The rising prices here cause people to buy less, which hurts the producers, who then buy less, and the cycle continues until all of the the false currency is accounted for, leaving the producers in the economy with nothing. When production stops, everything stops.
What's this got to do with global warming? In the coming depression, only the insiders will be allowed to produce anything. Because they will be the only ones who get energy rations. If you want to produce something and sell it to a willing buyer at a profit, you will only be allowed to do so if you have the influence to get the energy you need. Control over energy, and extraction of wealth by controlling the access to it, leaves you as powerless to resist as being in perpetual debt servitude. And a destitute people will be powerless to resist this take-over of the energy market.
--97T--
