588,531 active members*
8,567 visitors online*
Thread: THE GRIZZ
Page 28 of 37 182627282930
Results 541 to 560 of 726
  1. #541
    Oct 2013
    543
    Re: THE GRIZZ
    here are some quick videos documenting the custom homing sequence for mach4 that has been coming together over the last week. The machine is currently waiting on a replacement hydraulic seal for the draw-bar cylinder. Getting closer...
    https://youtu.be/VIjoA5kOhTg
    https://youtu.be/Dc-_CjMxNgE
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  2. #542
    Oct 2013
    543
    Re: THE GRIZZ
    Was able to run some test g code. Stuart made a cool floating sharpie holder. A touch of fusion and 'bob's our uncle'. If you notice the start date on "the grizz" build (12/9/16) ....happy one year anniversary! omg! Last week a new draw bar cylinder was made (other one was....leaking.."unapparent design flaw") . Tomorrow, planning on putting the draw-bar back together and testing.... fingers crossed.
    https://youtu.be/_uDYpKxTDvQ
    :cheers:
  3. #543
    Oct 2013
    543
    Re: THE GRIZZ
    Things are looking promising with the new draw bar cylinder!
    https://youtu.be/sxvwjMFmMgo
  4. #544
    Oct 2013
    543
    Re: THE GRIZZ
    playing catch up on the pictures... oldest to newest =)
    here is the electronics enclosure with all the wire duct snapped on, definitely tied the room together =)
    a sling-dinger ...
    The side windows installed
  5. #545
    Oct 2013
    543
    Re: THE GRIZZ
    sweeet!!! (hit up your local HVAC guy and have em make you a cool stainless edge guard)
    buttons, the labels are just printer paper.. the lens of the button comes off...
  6. #546
    Oct 2013
    543
    Re: THE GRIZZ
    Wanting something to stop large chips from going directly down the drains. I figure scuff-pads that have been "de-scuffed" look pretty "filter-esque" to me! Sharpened the end of a pipe in the lathe and punched the pads out on the hydraulic press. we shall see...
  7. #547
    Oct 2013
    543
    Re: THE GRIZZ
    If you recall there was a latency issue with having the wireless keyboard receiver inside the electronics enclosure. Moving the receiver "outside" the enclosure fixed the problem. Using a usb pass through and a un-unused 3/4" knockout got the job done. The fun part.... modeled and printed a snap on dome to cover the receiver. PETG per usual. I proceeded to drench the thing in black spray paint for that "just showered look". I think it was a post mock-up redo that turned out pretty good all things considered... i.e no major modifications required =)
  8. #548
    Oct 2013
    543
    Re: THE GRIZZ
    t-nuts and something to hold a vise on with.... check. parkerized... check.
  9. #549
    Oct 2013
    543
    Re: THE GRIZZ
    today....
    If you watched the video back a few posts you know what this is....if you didnt... this is the "iteration" 1 draw-bar cylinder.
    and the new one, it dosnt have cool pin stripes but at least it no longer weeps....
    that is it for today...
    :cheers:
  10. #550
    Re: THE GRIZZ
    Tis' beautiful! Truly production grade, makes me wonder how my G0704 even works.
    I started with Scotch-brite pads for filters for my drains, they tended to drain too slowly after not very much machining. My pump assembly has a separate 5 micron system in the coolant tank. The filter I now use in the enclosure is cut from furnace filter. It's dirt cheap and flows much better. Just some food for thought should you encounter slow drainage once you get cutting.
  11. #551
    Nov 2009
    4415
    Re: THE GRIZZ
    A swarf drawer technique would have allowed for incredible flow and easy cleaning.
    A lazy man does it twice.
  12. #552
    Oct 2013
    543
    Re: THE GRIZZ
    Thanks for the comments. Our tank is a two compartment deal with the first compartment sort of a settling area, then over a weir into the pump chamber. The pump is slightly elevated so some settling can take place here too. The Scotchbrite pads are just a early experiment. we have looked at the little 'crumb cups' you can buy for your bathroom sink and they look like they may work. It's going to be a work in progress kind of deal..I'm not sure what a swarf drawer is but it sounds interesting.
    We have yet to machine anything with this so technically, that fat lady hasn't uttered a single note yet!
    Stuart & Nick
    On a side note, this site is crawling again, and the page layout loads in a very strange format!
  13. #553
    Nov 2009
    4415
    Re: THE GRIZZ
    A swarf drawer would be just upstream of the final tank where the pump would be. This would have required a much larger trough under the base of your machine, then the drawer directly below. The bottom of the drawer is perforated and has a huge surface area, it is just over the final tank..
    The scotchbrite or even a bar sink strainer will clog quickly.
    You are doing exemplary work. Cant wait to see the results.
  14. #554
    Jan 2013
    28
    Re: THE GRIZZ
    I use Danco 88822 kitchen sink strainers in my swarf drawer over the drain. Place it upside down and let the swarf build up on it, a couple of magnets will hold it in place just fine.
  15. #555
    Re: THE GRIZZ
    I use magnets on standard drain covers and they hold in place the furnace filter, I place the furnace filter under the drain covers in a bowl shape to increase area. I actually have two swarf drawers, one for each drain. I think it's a battle between a bit of pre-filter cleaning or emptying swarf drawers. Either way I dispose of chips.
  16. #556
    Oct 2013
    543
    Re: THE GRIZZ
    Thanks again for all the ideas on swarf control in the coolant. I have only seen videos of CNC machines with enclosures running flood coolant and didn't really realize how it was filtered...no first hand knowledge so I appreciate all the hands-on comments. We have what we have, so as we get into actually cutting material we'll maybe have to make changes..don't know. I was sort of hoping the chips would fall into the pan and stick as the coolant flowed passed into the return drain, leaving all but the fines in the enclosure. Maybe I had my head where the sun doesn't shine...wouldn't be the first time.
    Stuart
  17. #557
    Re: THE GRIZZ
    They will be fine. The only time coolant really starts backing up on my machine is after I have like 3" of chips in the bottom of the enclosure. The worst thing that has ever happened to me after the drains backed up was that I had to clean them during a tool change. Literally 2 minutes of work.
  18. #558
    Nov 2009
    4415
    Re: THE GRIZZ
    I agree with CL on the fact you will do fine with this system.
    The method I was referring to generally has the bed of the mill suspended on a square or rectangular tubing frame over a trough maybe 8" x 18" for the 0704, with of course the drawer directly underneath.
    Of course you could do an auger. We would all expect no less for such a fantastic build ;-) I am kidding. It is going to need a live feed for the fan club!
  19. #559
    Oct 2013
    543
    Re: THE GRIZZ
    UPS came through with some spherical washers and low head cap screws for the vise hold downs. check.
  20. #560
    Nov 2009
    4415
    Re: THE GRIZZ
    Press Cycle Start! The suspense is agonizing ;-)
  1. enough yapping---grizz x3 //ordered// RECEIVED
    By project5k in forum Benchtop Machines
    Last Post: 01-09-2008, 11:50 AM
