603,314 active members*
1,879 visitors online*
IndustryArena Forum > CAD Software > Solidworks > "The sketch has no countor geometry"
Results 1 to 4 of 4
    Nov 2009
    71
    For some reason Soildworks 2008 recently started to act up giving me a message "The sketch has no contour geometry" basically I’m working on a sheet metal box and use the "base-flange/tab I get error mentioned above. I made sure all contours were closed even went as far as to use the rectangle tool and still get the same message.
    Any thoughts?
    Thanks,
    Eric
    Aug 2010
    90
    hei'ya eric, post the file or e-mail me and l'll try to see what's up - kelef
    Mar 2012
    Have you changed anything about the rest of the model since you started the sketch? If you referenced the sketch from part of the model, then since removed it or edited it then the reference would have got deleted and the sketch is just 'hanging' with no references to where it should be... I would try starting a new feature and do a new sketch referenced from something or somewhere else.
    Adrian- Mechanical Production Engineer- Hochiki Europe
    [SIGPIC][/SIGPIC]
    Mar 2022
    3
    Re: "The sketch has no countor geometry"
    Thank you for taking the time to share this information just fall lol
  1. Replies: 9
    Last Post: 08-16-2013, 09:28 PM
  2. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
