587,482 active members*
3,482 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Thoughts on MDF & Torsion Box Design
Results 1 to 19 of 19
    Nov 2006
    40
    Lightbulb Thoughts on MDF & Torsion Box Design
    I made the mistake of buying expensive baltic birch plywood to build my router with. Other than my local hardware stores only stocking 1/2" MDF in 4'x4' sheets, not quite long enough for what I wanted, I was trying to make my machine as light as possible, like many other people on this site are trying to do.
    I say this is a mistake because MDF is actually a great material to use for a few reasons.
    First, its cheap, dirt cheap. Enough said.
    Second, it has good accoustic damping properties. So although your router may not thump like a car stereo, not only will it help to keep the noise down but will also reduce nasty vibrations better than other materials will when you're cutting. This is especially beneficial if you're doing a surface finish operation.
    Third, MDF is heavy stuff. "But aren't most people trying to make their machines lighter?" you may ask. Yes, yes they are. "Why?" Well, to be honest, I think it's because as some point someone started making a bunch of cutouts to remove "unnecessary" material to save weight and the trend caught on. I'll agree that reducing the weight of MOVING parts has a benefits: more rapid acceleration and deceleration; and less wear on some components. But I argue that trying to lighten the base and table is waste of time/effort (design and machining), causes unnecessary tool/machine wear and will ultimately reduce the performance of your machine. For anyone who hasn't seen/used a full size metal working mill, lathe, etc., they're all large, heavy, steel structures. The bases and machine surfaces are basically steel blocks. This makes them heavy and stiff. Stiff is good because the cutting loads are large. Heavy is good for two reasons. It lowers the natural frequency of the machine [natural frequency = sqrt (stiffness / mass)], to something which is hopefully below the cutting speeds. A heavy machine also takes more force/energy to excite into vibration [vibration amplitude = (some constants / mass)], so if a machine vibrates up and down 1/32" inches, another identical machine twice as heavy would only vibrate 1/64".
    What I'm trying to say is that cutting a bunch of material out of your table is a bad idea. In fact, some of that "unnecessary" material may actually be doing something.
    I posted some images from an Finite Element model of a section of a router table. It's 36.5" long, 8.5" wide, with 4" high ribs equally spaced at 6" centres. The skins and ribs are all 1/2" MDF. A point load of 500 N (112lb) was applied at the centre. The modulus of elasticity of MDF used was 3 GPa (it typically varies between 2.5 GPa and 8 GPa, so 3 is conservative) and yield strength of MDF (modulus of rupture) is between 20 MPa and 80 MPa. (sorry, I didn't bother to convert to PSI).
    So what the analysis showed is that the maximum stress is about 0.2 MPa, or a safety factor of 100 (20/0.2) and the maximum deflection is 0.07 mm (.0028 in). It also shows that some of that "unnecessary" material may actually be not-so-unnecessary near the ends in the red region.
    I would love discuss these and related issues and hear what the rest of the community members think and have learned from their own experiences.
    Shawn
    Attached Thumbnails Attached Thumbnails Figure0001.png   Figure0003.png   Figure0004.png
    Mar 2003
    35538
    I don't know how that Finite Element stuff works, but the pics don't look quite right to me. The strength of a torsion box comes from the skins, and the sdhesive bond of the skins to the framework. Does that analysis take that into consideration? I would think that the stress on the skins would be spread out more evenly.
    Having said that, though, I'm mostly in agreement with you. Heavier is generally better, but you have the tradeoff of heavier being more expensive to move faster.
    My still unfinished router, is probably the first one using torsion boxes. I started building it in 2003. http://www.cnczone.com/forums/showthread.php?t=1356
    The torsion box ribs are baltic birch. At the time, I thought it was the best choice. And I drilled lots of holes to make them lighter. But they have a LOT of ribs in them, and they are still far from light. The large table has 1/2" mdf skins, and probably weighs 50-60 lbs. But it spans 60 unsupported inches, so I wanted to keep the weight down to minimize sagging under it's own weight.
    Now after spending thousands of hours reading over the last few years, I'm designing a bigger, faster, and better router. (I'll be finishing the first one by the end of the year) http://www.cnczone.com/forums/showthread.php?t=45844
    The torsion boxes in this new router will be MDF. Mainly for two reasons, though. It's cheaper. And the framework material has little to do with the strength. A few years ago I thought that a composite (carbon fiber / wood) machine would be perfect. Light and strong and fast. But I know understand that, as you've said, that light weight is not really the answer here. Although it's still a little important if you want reasonable (or better) acceleration, which is very important as well.
    So, my next machine will have a mostly MDF gantry, with reinforced 1/4" MDF skins for light weight, but with some epoxy / granite filler material to dampen vibrations a bit. So since I'll be adding a bunch of weight back in (in hopefully strategically placed locations), I'll still be drilling lightening holes in a lot of the rib materials. I'll have to wait and see how it works out.
    As for Baltic Birch, it has it's place. It's stiffer than MDF, and holds screws better. It will usually stay flatter, although it's not really an issue after proper sealing and finishing.
    Each material should be chosen based on it's intended application, utilizing it's strengths whenever possible. But your right, for a torsion box, MDF is right at the top of the list as far as materials go. Nothing at all wrong with using it, and no need to waste time and effort lightening it up.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2006
    138
    I believe these types of models will model the joints as though they're fully connected and won't give (other than the materials elasticity and such). This is probably a very accurate model, provided values of elasticity and such are correct.
    I too will be using torsion boxes, but I'm not going to go crazy on the sealing and hole cutting. I plan on using the CNC to re-cut my shotty wood working : \ Then I'll finish it up properly : )
    Apr 2006
    3498
    I belive these software gives best results if modeling and input parameters are realistic and accurate... this figure of deflection 0.07 mm seams realistic...
    Nov 2006
    40
    Hey Ger,
    I've definitely looked at your work, on several occasions, and am always impressed. I liked the "Alternative to round pipe" thread too. Glad to hear your router is going to be completed soon. I started university in 2003 and finished a little over a month ago, so if you look at it that way, someone can either build a router or go to school. The router is definitely cheaper.
    I added a few other pictures in response to your question about the images not looking quite right. You are right, the stress results aren't intuitive, so I added the maximum and minimum principal stress results. FEA works by breaking the body into a bunch of tiny pieces and analysing the interactions between the pieces. If the pieces are assumed to be little cubes, because cubes are easy, and I like easy, you can imagine rotating them around in different orientations and having the reactions at each face change as the cube is rotated. The maximum and minimum principal stresses are 90 deg apart and correspond to the orientation of the cube when the forces on its faces are at a maximum/minimum. Maximum doesn't necessarily mean largest, rather "biggest positive value or negative value closest to zero," whereas minimum means "biggest negative number or positive value closest to zero." This is important because a negative stress implies compression and positive implies tension.
    As for the model itself, I did it as if the skins and ribs are all one continuous body. So it actually considers the skin-rib and rib-rib joints to be perfect. I also extended the legs to minimize the effects the constraints have on the torsion box itself.
    Before I make some comments about the pictures, note that RED DOES NOT NECESSARILY MEAN BAD. It just represents the upper range on the scale.
    This first one shows how the torsion box section would deform. Ignoring the legs, the ends deflect very little while the most sag is in the middle, the blue section.
    Here we have the maximum principal stress. The orange on the bottom, according to the legend, means that the bottom has a positive stress, ie tension, and that this is where the highest tension occurs. The blue on the top shows that if the "cubes" are rotated in a particular orientation, they experience a very small amount of tension (but it could actually be zero because zero lies in that colour band). Conclusion: The bottom is stretched in tension, and physically this makes sense.
    Next up is the minimum principal stress. The red on the bottom, according to the legend, has a stress somewhere between -0.09 MPa and + 0.12 MPa. (Note that zero stress is also in this range.) And the orange, green and blue sections on the top all show a negative stress, meaning the top is being compressed. Conclusion: The top is under compression from the bending, and this also makes physical sense.
    Putting the previous conclusions together, the model behaves as expected if a force was applied to the top of this section of a torsion box. Also notice that the ribs don't experience a lot of stress, but do keep in mind that they still must transmit force from the top to the bottom. In order to come up with a meaningful failure model, the maximum and minimum principal stresses need to be combined. This is done using the Von Mises criterion, which is based on material failure theory. The equation used to do this is:
    equivalent stress = sqrt ( max_princip_stress^2 - max_princip_stress * min_princip_stress + min_princip_stress^2 )
    So for the most part, the highest stress is in the skins towards the middle, where it would be expected. The cross ribs don't appear support a whole lot, which makes sense because they're perpendicular to the bending direction. The longitudinal rib has interesting stress patterns, with some high shear areas near the ends but supporting very little towards the middle. It appears as though most of the loads are transmitted from the top to the bottom through the yellow bands in the longitudinal rib.
    A simple beam in bending would have purely axial compression on the top and axial tension on the bottom, with the highest stresses and deflection in the middle and no stress or deflection on the ends. I think that for the most part this model's behaviour agrees with a simple beam.
    Shawn
    Apr 2006
    3498
    Nice to see your work SHAWN...Can you do stress analyses on Joes 2006 design???...
    I didn't work on ANSYS...As I mechanical engineer and working in process plant,I have a little experience working on CAEPIPE/CEASERII,COMPRESS, COADE CODECALC etc..
    These softwares are great to get optimum designs and tell us the problamatic areas...
    Mar 2003
    35538
    Quote Originally Posted by the__extreme View Post
    This first one shows how the torsion box section would deform. Ignoring the legs, the ends deflect very little while the most sag is in the middle, the blue section........................................... .
    Wouldn't a torsion box deform more evenly, as the skins should spread the load out?
    And a torsion box should not behave like a simple beam, should it?
    Gerry
    Sep 2003
    1113
    Just another thought on comparing MDF and plywood (Baltic Birch -- very nice, but any marine ply would suffice -- no voids, good glues) for the torsion box:
    Sheer failure in the webs.
    MDF will sheer when loaded due to its lack of "grain" -- which is not unlike the filaments of glass in fiberglass. The loads are taken along the "grain/filaments, and reduce sheer stress in the webs.
    Another example - consider the number of homebuilt aircraft built with MDF -- 0. And the wing structure is an oversize torsion box! MDF has its place, but a plywood - torsion box will have much better mechanical properties.
    Like the idea of using FEA though!
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Nov 2006
    40
    A torsion box works much the same as an I-beam. They both have a high moment of area about their neutral (central) axis for their weight and for this reason resist bending very well. If you have a beam, say a 4' long 2"x4", and support it at its ends and push on the middle of it, it bends a lot more easily if it's flat then if it's on edge. That's because the moment area is the width * height^3 x (1/12), so its 4 times as stiff in that direction.
    _______
    |______| (1/12) * 4 * 2^3 = 32/12
    vs
    ___
    | | (1/12) * 2 * 4^3 = 128/12
    | |____________central/neutral axis
    |__|
    Since I-beams and torsion boxes put more of the material farther away from the central axis, they make good use of a small amount of material.
    The stress in a bending beam varies with the distance from the central axis also, but linearly, not cubed: Stress = bending moment * distance / moment area. Since nothing we're making is breaking...I hope...everything should behave elastically, so the strain, or deformation, is related directly to the stress. By placing material as farther away from the central axis, the member is stiffened, which reduces stress, reducing deformation and deflection.
    This will be true of any structure, simple beam or torsion box. The difference between a torsion box and an I-beam is that the torsion box essentially has I-beams running in both directions, so it resists bending in 2 directions. As for the 'torsion' aspect, again, having the material farther from the neutral axis has the same effect. The ideal shape to minimize torsion/twisting is a large diameter, hollow pipe, because the material all as far away from the pipe's axis as possible.
    It's actually kind of interesting to note that most people, myself included, only support their torsion boxes at the two ends. In this configuration, it really acts more like a couple I-beams than a torsion box, and would actually be much stiffer if it was supported around all its edges.
    As for the simple beam, I decided to analyse it too to see what the differences were. Turns out, not too many. But really, bending is bending and I shouldn't have expected there to be any huge differences. The top surface is compressed, the bottom is stretched and the highest stress is in the middle, pretty much the same as the torsion box.
ID:	61820 Click image for larger version.
ID:	61821 Click image for larger version.
ID:	61822 Click image for larger version.
    High Seas,
    I agree with the shear failure. In fact most materials fail in shear, except brittles like ceramic. That is essentially what the "equivalent stress" images show. Its approximately the difference between the maximum and minimum principal stresses at any point, which is the shear. A plywood will resist shear much better because of the different lamination/grain directions. I'm actually in the process of designing some fibreglass wind turbine blades, but our problem is fatigue not shear. Don't want to throw a blade...another blade...
    Khalid,
    I'm hoping to fun my own machine through some of the advanced analysis tools, like interactions of all the components (gantry, router carriage, table, etc.) and maybe a modal analysis to see if it will resonate at any cutting speeds. Still some learning to do first though. I think it would be really interesting to run Joe's routers through the program, I'm a big fan of his work. Keep in mind that software is great stuff, but it can still give poor or inaccurate answers if the inputs are incorrect. The results should always be compared with the expected behaviour.
    Cheers,
    Shawn
    Mar 2003
    35538
    Quote Originally Posted by High Seas View Post
    If your talking about the edge of the MDF, I'll disagree. Bond the skins with epoxy, which will soak deep into the edge of the grain, and it'll be very difficult for the edges to shear off. If you're talking about the skins, then I'll agree a little. But the quantity of interior members greatly affects the load required for this shear to occur. If you want a stronger box, increase the density of the core.
    Also, at what force do you think this shear will occur? A cheap hollow core door, with 1/8" masonite skins and a CARDBOARD core, will support a few hundred pounds pretty easily.
    Gerry
    Nov 2006
    40
    I think Jim was talking about general shear in the MDF/plywood, not necessarily the edges. It's easy to peel apart the grains in a sheet of plywood, but takes much more force to break a grain if you're pulling on it from the two ends, in other words the directional nature of wood. Since MDF is a very nondirectional, uniform material, you don't get the advantage of longitudinal tensile grain strength as in a laminated plywood or fibreglass.
    I agree, I wouldn't expect that your joints would ever come apart at the edges they way you've bonded them. I read that MDF has a tensile strength / modulus of rupture between 20 - 80 MPa (2900 - 11600 PSI). The actual force would depend on the size/orientation of the piece.
    May 2006
    138
    They also build model planes out of balsa wood, but I wouldn't be building a router out of one.
    Comparing planes to a router is nonsensical. The wings in a plane are designed to act as shock absorbers. They can bend and flex in strong wind, and especially in high turbulence. Taking a look at this video will clearly show their design goals of a wing. To top it off, planes need to be kept light and vibrations are less of a concern. In that sense, MDF makes no sense at all.
    On the contrary the weight of a router is the opposite of a plane. The more the merrier. Making it heavier you will be dampening the vibrations caused by the router, allowing for smoother finishes. Also, denser materials tend to bend less, making for a structure that flexes less.
    Apr 2006
    3498
    i didn't see anywhere planes made out of MDF..Usually balsa wood is used that is very light weight and expensive..
    Sep 2003
    1113
    Ger 21 - Et all
    sorry for the late reply...
    the_extreme
    Right> Thanks.
    I'm talking of shear failure in the WEBs -- not the edges. A common failure in foam cored applications - not unlike MDF in this case - is the actual failure of the material between the surfaces. The flat upper and lower surface are supported by the WEBS - but if the WEBS fail - due to sheer stress - the torsion box fails.
    Now, for most light weight applications - may not require FEA to get to a solution - consider this:
    MDF is a "foam-like" product when used as "core" be it a door - or a torsion box. (Mind, you doors are an interesting structure in themselves)
    The reason planes are not made of MDF - very high weight and very poor strength properties.
    Gir:
    The comparison to aircraft comes form my experience as an enginner and aviator --- and now "boy-machinist." Weights, loads, stress, and strength required in a torsion bosx is similar to an aircraft (win) - but -- yes the router DOESN'T need to FLY! -- BUt weight usually equals CO$T. Damping is what is required -- yes - and there are better materials for that than MDF!
    Kahlid :-
    balsa is not as expensive as it sometimes seems - given its properties--but not always available worldwide -- Supply and Demand!.
    So, I'd offer the following:
    Stability - in humid conditions or changing humidity
    Rigidity - stable and won't bend or sag (mind you small - but expect you want good/constant repeat-ability at different sites)
    Durability - no glue failure due to moisture intrusion
    Mechanical - ease of attaching fittings, screws, etc...
    Now - MDF could be fine knowing given the considerations offered above -- but -- I'd opt for good quality ply.! {BTW I dumped a 24x24x8 (in) set up in MDF for all the above -- now using it to support my dremmel scroll saw in the garage!}
    :cheers: Jim
    Jul 2003
    276
    Does the analysis of the torsion box also include the inner ribs and skins on all 4 sides? In the pictures it appears to have an open front.
    My first test of a torsion box had 10 ribs vertically and 4 ribs horizontally and was very flimsy until it was skinned on top and bottom.
    Nov 2006
    40
    Quote Originally Posted by randyf1965 View Post
    Hi Randy,
    The model is basically a lengthwise cut-out of one section of the torsion box, supported at both ends the way most of us are building/have built our routers. The top and bottom are skinned, but the open sections you see are actually the sides, not the front. The sides were left open so that the internal structure could be seen, which should not affect the analysis because the load was applied vertically, at the center, above the lengthwise rib so that no twisting would occur. Although the loading would not be identical, you could imagine connecting 4 of these sections side-by-side to give you the 4 horizontal ribs that you used in your torsion box. The center-to-center spacing of the ribs in both directions is 6" and the ribs are 4" high, with 0.5" thick skins.
    I agree that this structure would be very flimsy without the skins, and if it was to be twisted, even with the top and bottom skinned, would perform poorly because the sides are open.
    Shawn
    As a little bit of a side note, for anyone wanting to scale up or down a torsion box, in order to get the same deflection under the same load, increase the box thickness (ie. rib height) proportionally with the supported box length. The deflection varies with the supported length cubed, and the resistance to bending with the thickness cubed. Increasing both by the same percentage cancels out.
  17. #17
    Mar 2006
    16
    You can download a stl file for blade:
    http://www.partenovcfd.com/software.html
  18. #18
    Jul 2007
    1602
    Shawn,
    Can your software calculate what would happen if you would fill the cavities in the torsion box with expanding foam?
  19. #19
    Oct 2008
    242
    are there any longitudinal beams? The horizontal ribs aren't really doing anything in the pictures, it's the long beams that are supporting the weight.
  1. Torsion box design in depth info?
    By Oldmanandhistoy in forum WoodWorking Topics
    Last Post: 02-09-2008, 11:59 PM
  2. 8020 and gas pipe design thoughts
    By jvanick in forum DIY CNC Router Table Machines
    Last Post: 12-06-2007, 12:14 AM
  3. thoughts on an X Y A machine design
    By bfreedland in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 08:17 PM
  4. 80/20 torsion box and router design
    By KTP in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 03-01-2006, 04:24 AM
  5. First thoughts for new design
    By Pairair in forum DIY CNC Router Table Machines
    Last Post: 09-10-2005, 04:19 PM
