588,138 active members*
7,073 visitors online*
Results 1 to 15 of 15
    Oct 2007
    34
    Thread Milling
    Hi guys,
    I need you guys help on thread milling. The truth is, I didn't have any formal training on Mastercam. I just learn it by my own.
    I need to tap a depth 16mm blind hole using M10 X 1.5 tap, but the DWG required the tapping depth of 14mm. I tried several times with normal tapping, but couldn't achieve the 14mm depth required. So I left with thread milling option, but I don't know how.
    I hope you guys can help me on this.
    I'm currently using Mastercam 9.1 and the material I need to tap is Stainless Steel.
    An example on Mastercam 9.1 on how to create a thread milling toolpath is very much appreciated.
    Thank you
    Regards,
    David Samuel Rosario
    Malaysia
    Dec 2009
    80
    Hi, what is the diameter of your thread cutter, and how many teeth?
    Oct 2007
    34
    Hey Limpan,
    Thanks for your quick reply.
    Thread cutter diameter is 8mm with only 1 active teeth.
    Sep 2008
    51
    Hi mrsammy,:wave:
    I think this is just what the doctor ordered.
    Good luck!
    http://www.streamingteacher.com/samp...9_milling.html
    Dec 2009
    80
    Ok, well, diameter 8mm is very tight for making M10 threads but I still think it could work.
    I'll have a look at it later tonight (it's almost 7 PM here) /Limpan
    Dec 2009
    80
    Hi again, try these settings, see picture.
    Limpan
    Apr 2003
    3578
    M8 thread hob is not that small as O have done allot smaller. looking a Lipman's setting the pitch is correct review from the picture of my settings on a project I have running now. this from X4 but the pitch is not metric unless you are use a Metric Machine and post. Take the 1.5mm /25.4 for the pitch.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Oct 2007
    34
    Sir,
    Thanks for the reply. I appreciate it very much.
    Oct 2007
    34
    Limpan,
    Thanks so much for your help my friend. I appreciate it very much.
    Nice to know in here so many good people like you.
    One more thing...is the feed rate and rpm using the same normal tapping calculation?
    Dec 2009
    80
    Hi mrsammy, as you are milling your thread instead of using a tap cycle you don't have to calculate spindle speed vs feedrate depending on the thread pitch. If your thread cutter is made of solid carbide i would recommend a spindle speed around 2000 rpm, and start with a feedrate around 150-200mm/min for stainless steel. If the cutter is made of high speed steel (HSS) you should reduce the spindle speed to about 800 rpm and feedrate about 60-80 mm/min. (Keep your hand on the feedrate override pot.)
    Limpan
    Oct 2007
    34
    Dear Limpan,
    Thank you so much for your useful information. As you already know, I did not have any formal training on mastercam (I just learn through my experience).
    I feel very lucky to know that so many people out there have a good heart like yourself.
    Thank you once again.
    Dave
    Nov 2008
    6
    Hi mrsammy,
    what is the tool manufacturer? I am looking for single thread cutter. I found only cutter for aluminium. Thanks
    Jul 2010
    Hi Smrkoul
    I need information spindle speed, feed rate and depth of Aluminum. i use thread cutter is 9/16-18 inch with dimension hole is 0.5156 inch. Can you show it?
    Nov 2008
    6
    Quote Originally Posted by huuloc1320 View Post
    Hi Smrkoul
    i use cutting conditions posted by manufacturer. I use Dormer thread mills (i think, it is sandvik group) Check http://www.dormertools.com ..... milling tools -> thread milling -> ....
    Jul 2010
    Quote Originally Posted by Smrkoul View Post
    Hi
    I think your information are very helpful.
    Loc
  1. Thread Milling
    By sambo67 in forum MetalWork Discussion
    Last Post: 02-13-2010, 07:10 AM
  2. thread milling help
    By BAD DOG in forum Daewoo/Doosan
    Last Post: 11-28-2008, 07:20 AM
  3. 3M and thread milling?
    By teamjnz in forum Fanuc
    Last Post: 11-04-2008, 02:09 AM
  4. Thread milling
    By wjfiles in forum MetalWork Discussion
    Last Post: 01-08-2007, 11:13 PM
  5. 0M-Thread milling?
    By mikul in forum Fanuc
    Last Post: 12-06-2006, 06:56 AM
