588,555 active members*
4,692 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Thread Milling on M32 sub. without Y axis.
Page 1 of 2 12
Results 1 to 20 of 23
    Oct 2007
    24
    Thread Milling
    I just wanted to know if anybody out there has thread mill on a M32 citizen on the sub. without having Y axis on the turret? I know it sounds like it would be able to, using X, Z, and C axis. But has somebody actually done it. Thanks
    Jan 2008
    12
    THIS IS A PROGRAM I RAN TO THREAD MILL A 3/8-16 THREAD IN A STAR SV-32 MACHINE.The "y" in this program is like "x" in most machines.
    N5(ID THREAD-3/8-16)
    G98M8(C-AXIS ON / IN. PER MIN.)
    G0C0.
    T2064(ID THREAD MILL)
    #124=0.50(Z-DEAPTH)
    #125=[#124/.0625*360]
    G97
    M47S1000(LIVE TOOL ON)
    G0Y0.0T64
    G0Z-0.10
    G0Y0.145
    G1W0.50H-#125F2000.
    G0Y0.0
    G0Z-0.10
    G28V0W0T0
    M48
    M9
    G99
    M1
    Oct 2007
    88
    With all due respects to all responses, it kind of looks as if the above program is a hard numbered program for a thread whirl instead of a thread mill. That looks like our G32 for taps and screws where the H axis is our degrees in C. Thread milling should move in an actual Y axis. Otherwise I think your degrees that the C axis moves will make the thread "cave in" on itself. The more it moves in C one way, the closer your major diameter comes to touching itself. If you make a hole in G16, The hole is not round as it is eggshaped.
    Jan 2008
    12
    This is the way I have thread milled alot of parts using a single form thread mill. It seems to work real well. The threads look good and the thread gages work fine.
    Oct 2007
    88
    On an ID thread?
    Oct 2007
    88
    how are you setting your helical angle?
    Oct 2007
    24
    Thank you for the replys, ok i have read all of your replys but here goes a nother question. Same question as above but the thread being off center. I have a friend that is trying to thread mill an off center hole just using X,Z, and C axis. Can that be done and has somebody actually done it. The machine makes the movements but it is leaving a 2 flats on the major of the threads.
    Oct 2007
    24
    sorry i meant to write minor not major, sorry
    Oct 2007
    88
    Remember, you must take in to account the helical angle like whirling. The formula for that is tan-1[pitch/[pitchø*pi]]. Your flat is probably being caused by that. You still can not properly threadmill with out a proper Y axis or a tool that can be positioned at an angled other than 0/90
    Oct 2007
    88
    It might be in good interest to remember that thread mills are expensive. The average cost i hear is 100. Taps are much cheaper.
    Oct 2007
    When the program posts it looks like this.
    G0 G90 Z1.
    G0 X.19 C_V$WSP$=180.000
    G0 Z.1 F0.002
    G1 Z0.
    G0 G90 Z-.5206
    TRANSMIT_S_V$WSP$
    G0 X-.19 Y0.
    G1 Z-.56
    G1 G41 X.2475 Y0.
    G3 X.2475 Y0. Z-.51 I-.4375 J0.
    G3 X.2475 Y0. Z-.46 I-.4375 J0.
    G3 X.2475 Y0. Z-.41 I-.4375 J0.
    G3 X.2475 Y0. Z-.36 I-.4375 J0.
    G1 G40 X-.19 Y0.
    G0 Z.0394
    G1 X-.1691 Z1.
    M_V$WSP$13
    TRANS_OFF
    M_V$SP$=5
    L_V$COFF$
    G18 G40
    VERSCHIEBUNG("OFF")
    M_V$K$09 M_V$K$55
    L710(1)
    NN9999: M17
    Here is a screen capture of what it looks like the attachment.
    Jan 2005
    304
    NOTE!!!!
    DO NOT use a "Y" axis command for your turret unless you enter milling interpolation FIRST or you could damage the index mechanism. Even "Y0" will do this unless you have the newest version of software in the control.
    Been there, Done that and paid dearly!
    Jan 2008
    12
    I am still confused why you would need a y-axis and why the helical is a problem. When you rotate c-axis that is just like moving x and y in a mill.
    When you are thread milling in a mill your tool is not positioned on an angle.I have thread milled several parts in a star machine using c-axis and the parts looked fine and checked fine.
    Jan 2005
    304
    SWISS-TECH is correct you do NOT need to have the "Y" axis to threadmill. The tool would be made with all the angles in it either way. Somebody seems to be confusing Thread Whirling with thread milling.
    Feb 2006
    992
    Quote Originally Posted by tejano4life72 View Post
    the simple answer to your question is "Yes" but you need CAD/CAM to generate the toolpath/will take you forever to convert Y coord to angle.
    The best way to learn is trial error.
    Jan 2005
    304
    You will NOT need to convert the "Y" axis commands yourself when using the Milling interpolation option. The control will do the work for you. (G12.1)
  17. #17
    Oct 2007
    24
    I know that G12.1 will convert C to Y axis. But will it work on a off center hole? I know the turret will over travel. But if it didnt over travel will it still work. Having X,C, and Z working together on a offset hole? G12.1 works good on X and C "Y" but how about all 3 axis.
  18. #18
    Feb 2006
    992
    yes, you need to order option 3 axis move to do XCZ move.
  19. #19
    Feb 2005
    303
    Yes, I have done it, exactly what you're referring to...
    thread milling
    internal thread
    off-center
    using the turret
    on the sub
    of an M-32
    without a true Y-axis.
    And here's the helpful part...
    It was five years ago, and I don't have a copy of the program. (previous employer)
    22-13-5 stainless was hard on taps, it milled much easier.
    And we were making small pressure fittings, so threads without flats/scallops was essential.
    iirc, it was pretty straightforward...
    rapid to cl of hole
    lock spindle in milling mode
    rapid to (depth - 1 thread)
    helix move to majorØ over a Z length of 1/2 thread lead (Important, to keep the thread crest from getting truncated)
    helix move to depth
    helix move out to cl of hole.
    That being said, your code looks very strange to me:
    M_V$WSP$13
    TRANS_OFF
    If this is what is posted, does it actually work?
    My apologies for not having the code handy... it was literally 5 years ago, and I haven't laid hands on a CinCom program for at least three.
    But half the battle is knowing it can be accomplished, yes?
    I will look through my notes from back then and see if I can find something a little more helpful...
  20. #20
    Oct 2007
    24
    That code will look strange to you ghyman cause its not for a citizen, its for a DMG Gildemeister twin 65 machine. My friend is trying to do it on thier. I just figure if the citizen can do it that machine should be able to do it. I want to thank everybody for their input.
Page 1 of 2 12
  1. Thread Milling
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 08-02-2011, 12:48 AM
  2. Thread Milling
    By ragman in forum MetalWork Discussion
    Last Post: 02-05-2008, 04:04 AM
  3. Y axis thread milling
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 12-21-2007, 07:57 PM
  4. Thread Milling on a 5 axis lathe
    By Jr. Programmer in forum G-Code Programing
    Last Post: 07-28-2007, 01:09 PM
  5. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
