603,896 active members*
5,808 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Thread milling with single or multiple inserts?
Results 1 to 9 of 9
    Apr 2007
    52
    Is there a difference in programming using a single insert versus a multiple insert cutter? Thanks in advance!
    Mar 2005
    988
    No, not really. The speed/feed is still based upon the same parameters (cutting diameter, thread pitch, material, etc). The benefit is the improved finish quality, potentially faster feeds and possibly longer tool life.
    It's just a part..... cutter still goes round and round....
    Apr 2007
    52
    Thanks for the reply. I wasn't sure if it would matter or not. Does the type of cutter make a big difference in the program? Such as a insert with multiple teeth to cut with versus a single edge cutter. I used the Vardex TM generator to make some code to give me an idea on what it should look like. But depending on wether you select continuous thread or axial it looks alot different. It depended on which style of cutter, depth and diameter wether you could select either option or not. I would prefer one continuous cut unless there is a reason not to do that. Any comments are appreciated. Thanks in advance!!!!
    Mar 2005
    988
    Yes it makes a difference... but mainly for the initial depth at start and the number of turns you make before you exist. Long edge inserts (multiple teeth) allows you to start deeper in the hole (for instance) and maybe only have to make one revolution to complete a thread and exit.
    Single edge (AKA single point) types means you literally have to match the number of programmed revolutions as according to the depth of thread you want. For example:
    1/4-20 x .300 deep
    20TPI = .05 pitch
    So, in theory, to achieve this deep and full threads, you'd have to make 6 revolutions with a single point (at the bare minimum - just using easy numbers here...). With an insert with multiple teeth, you only have to make 1 revolution since the insert is at least that long.
    I don't use the Vardex TM generator so I'd have to see it to get what's going on. But I think what I'm mentioning above is the differerence in the software output....
    Dec 2006
    95
    Magneto, We switched from single insert threadmills when Vardex came out with the new design. Man it cut our cycle time down big time. I also use a big one made by Tool-Flo in Houston for a tapered oil country thread. 5-Flute 1000SFM @ .005 per tooth. Sounds like a buzz saw in there. Great tool life, beautiful finish, can't hardly believe it. On an old Mazak H-15B too!
    Apr 2007
    52
    Thanks for the replys. Here is the code im talking about this is for a 1.25x11.5 npt thread that is 2" deep. It is climb milling in cast aluminum and its using a axial divide path with a single insert cutter that is about 1" long.
    O10(TMINRH CLIMB INCH CYCLES =2)
    (Tool cutting diameter = 1.378 inch - Mazatrol Controller. Use the ISO routine on your machine.)
    (Taper=1/32.0 dAlfa=22.5 Second Loop Teeth=8)
    G94
    G90 G00 G57 X0 Y0
    G43 H10 Z2. M3 S554
    G91 X0 Y0 Z-2.8021
    G91 G01 G41 D60 X0.1315 Y-0.7892 F0.53
    G91 G03 X0.7892 Y0.7892 Z0.0195 I0 J0.7892 F0.53
    G91 G03 X-0.2694 Y0.6513 Z0.0109 I-0.9209 J0.0004 F1.77
    G91 G03 X-0.6513 Y0.2701 Z0.0108 I-0.6517 J-0.6511
    G91 G03 X-0.6518 Y-0.2696 Z0.0109 I-0.0004 J-0.9216
    G91 G03 X-0.2703 Y-0.6518 Z0.0109 I0.6516 J-0.6522
    G91 G03 X0.2698 Y-0.6523 Z0.0108 I0.9223 J-0.0004
    G91 G03 X0.6523 Y-0.2705 Z0.0109 I0.6527 J0.6521
    G91 G03 X0.6527 Y0.2701 Z0.0109 I0.0004 J0.9229
    G91 G03 X0.2707 Y0.6527 Z0.0108 I-0.6526 J0.6531
    G91 G03 X-0.7892 Y0.7892 Z0.0195 I-0.7892 J0
    G00 G40 X-0.1342 Y-0.7892 Z0
    G91 X0 Y0 Z0.5702
    G91 G01 G41 D60 X0.1532 Y-0.7892 F0.53
    G91 G03 X0.7893 Y0.7892 Z0.0190 I0 J0.7892 F0.53
    G91 G03 X-0.2758 Y0.6667 Z0.0109 I-0.9426 J0.0004 F1.77
    G91 G03 X-0.6667 Y0.2764 Z0.0109 I-0.6671 J-0.6665
    G91 G03 X-0.6671 Y-0.2760 Z0.0109 I-0.0004 J-0.9433
    G91 G03 X-0.2767 Y-0.6671 Z0.0108 I0.6670 J-0.6676
    G91 G03 X0.2762 Y-0.6676 Z0.0109 I0.9440 J-0.0004
    G91 G03 X0.6676 Y-0.2769 Z0.0109 I0.6680 J0.6675
    G91 G03 X0.6681 Y0.2764 Z0.0108 I0.0004 J0.9447
    G91 G03 X0.2771 Y0.6681 Z0.0109 I-0.6679 J0.6685
    G91 G03 X-0.7892 Y0.7892 Z0.0191 I-0.7892 J0
    G00 G40 X-0.1560 Y-0.7892 Z0
    G90 G00 Z8.0000
    G49 M5
    M99
    Is there a code in G or mazatrol that will let me select a continuous or axial path?
    Dec 2006
    95
    Just out of curiousity, why is the thread so long? API 5B calls for the thread to be 1.0625 + or - one thread.
    Apr 2007
    52
    I just made it that long. We never run any that long. I did it for a example.
    I've been doing some homework and i understand the code you gave me more
    the I code is the increment along the x axis from the start point of the arc to the arc center.
    The J code is the increment along the Y axis from the start point of the arc to the arc center.
    Apr 2007
    52
    Here is a snippet out of the programming book I got from mazak. Does this look kosher.
    http://img359.imageshack.us/my.php?i...doc4152kd6.png
    http://img87.imageshack.us/my.php?image=sdoc4151er0.png
    Thanks in advance!
  1. Thread milling help!
    By asjad in forum CNC Machining Centers
    Last Post: 09-21-2008, 04:47 PM
  2. APET Milling inserts
    By Billet Sean in forum MetalWork Discussion
    Last Post: 02-27-2007, 08:35 PM
  3. Silicon Nitride Milling Inserts?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 02-12-2007, 03:23 PM
  4. Thread milling single point tool
    By Ikon in forum MetalWork Discussion
    Last Post: 08-22-2005, 11:15 PM
